SYNC Frustrations....and Knowledge
Old Jul 31, 2014 | 01:23 AM
Tofan's Avatar
Tofan
So I just upgraded my phone about a month ago from a flip phone that I used for years to a sweet Nokia Lumia 925 windows smart phone. I have had the iPhone but that was when they first came out etc. Well I have been finding out all this cool stuff that I can do with my phone and my truck. Well one of those great things is streaming music through bluetooth. Well maybe about a week ago, my phone just froze up and lone and behold, I couldn't play music through bluetooth anymore. I still had the phone function and it worked perfect, but I couldn't play music through the truck. The phone would say that it's playing, but no sound would come out of the speakers and the radio said that there was no bluetooth audio device found. Again, the SYNC for my actual PHONE works, but the playing music part just won't work. Numerous calls to the dealer and SyncMyRide.com and nobody knew what was wrong and told me to take it to the dealer. Well my local dealer is booked out almost 2 weeks at this point for any sort of appointments. So after scouring the inter web for HOURS trying to find any sort of fix swearing to myself the whole time , I saw a thread about removing the SYNC fuse from the fusebox located near the passenger side kickspace(under the glovebox). I also learned something new here, Ford included a fuse puller on the inside of the plastic part that pulls off to reveal the actual fuses. So I pull the fuse(#29 in case anybody is wondering, it's in the owners manual, approx pg 285) and wait a couple of minutes. I put the fuse back in and all of a sudden my AUDIO CAN PLAY and I can once again JAM!
So for anybody out there that is having any sort of SYNC problem, I highly recommend to pull the fuse(#29), wait a minute or two and plug it in and see if that resolved your issue. Ford Support couldn't help me with anything more then I need to take it to the dealer. This was very frustrating as the radio stations in my area are subpar at best. Pictures will be uploaded tomorrow of said fuse box and location for those who don't know where I'm talking about.
Old Jul 31, 2014 | 05:04 AM
senix's Avatar
senix
you reset the radio.
Did you also try to completely remove the phone out of he sync system and then re-add?
Old Jul 31, 2014 | 05:37 AM
jdadamsjr's Avatar
jdadamsjr
what he said - re- syncing phone did it for us on both cars...
'memeber - it's Microsoft it HAS to be rebooted every once in a while
Old Jul 31, 2014 | 05:55 AM
yfz 450's Avatar
yfz 450
I can't even get my iPhone to play music through the truck when it's plugged into the USB port any ideas on that?
Old Jul 31, 2014 | 06:03 AM
senix's Avatar
senix
I should automatically see the usb. My better half uses it and it sees it and switches to it right away.
Try to manually switch using the media button.
Old Jul 31, 2014 | 07:56 AM
StanleyZ's Avatar
StanleyZ
That's a great post, thank you. The whole sync experience drives me crazy. The GPS is way hard to figure out. I have that and an RV GPS and an $80 Tom Tom. The tomtom is by far the most accurate and user friendly. I wish I had a recording to post of me trying to use the voice feature. It is probably funny as heck, but not to me. Thanks again.
Old Jul 31, 2014 | 08:00 AM
yfz 450's Avatar
yfz 450
I have tried switching manually as well and it won't work.
Old Jul 31, 2014 | 08:47 AM
BlackNM6.0's Avatar
BlackNM6.0
I had a similar issue with my former Expedition and my wife's Fusion. Normally the SYNC would find the ipod/iphone(I tried two ipods and an older iphone 3g) and play it as it should but about every two weeks or so it wouldn't recognize the device and on some ocassions it wouldn't even find the USB and the media button would only cycle thru the radio and XM stations and skip the media stuff all together. Drove me nuts because I typically only listen to my ipod, not XM or radio.
So far the only quirky thing SYNC does in my truck is it doesn't start the music on the ipod, I have to go in and press PLAY.
Old Jul 31, 2014 | 09:23 AM
BCM's Avatar
BCM
Try a different cable for your iphone/ipod. That fixed it for me. The one in the truck worked for my kid's devices, but not mine. I replaced it with the one I used for charging in the house and it worked.
Old Jul 31, 2014 | 09:55 AM
BlackBeest's Avatar
BlackBeest
That's exactly what I was about to suggest. USB cables are not all the same.
On an unrelated note, I'll share a hopefully helpful tip regarding an issue I had with my SYNC. If you ever try to call someone on your contacts list, using the voice prompts, and get the "Calling Dot", or "Call Dot on cell, at home, at work, (etc)? It's because you've got either emoji's or punctuation hiding in your contacts on your phone, and it's throwing SYNC a curveball.
I fought that for months before finally discovering the problem. I went through every one of my contacts removing any punctuation or smileys, then re-synced it and voila! All contacts were voice dial-able again!
HTH,
Old Jul 31, 2014 | 10:31 AM
SavageNFS's Avatar
SavageNFS
Apples are notorious for needing apple brand cables or high end aftermarket cables. Good idea...
Old Jul 31, 2014 | 12:40 PM
hemi79's Avatar
hemi79
I actually like the Navigation on my F250 more than other aftermarkets ive had. Even my samsungs phone nav. Tried it recently and the partial window detailing the upcoming next turn is pretty nice i think.
Old Jul 31, 2014 | 01:12 PM
donovan's Avatar
donovan
Reset phone
I have had the same issues the phone stops play while driving. Drop phone in sync and then add it, and it works. BUT why in the middle of driving. I replace the factory stereo and it works better with the Kenwood then Sync.
Old Jul 31, 2014 | 01:54 PM
yfz 450's Avatar
yfz 450
Ok thanks I will try an apple USB the one I was currently using was not. Hopefully that is it
Old Jul 31, 2014 | 02:40 PM
Tofan's Avatar
Tofan
Yes I did probably 50 times. Everytime I un-paired and re-paired and each time the phone would work, but not my music. I even did the "master-reset" on the actual radio in the menu, which still didn't allow the bluetooth audio part to work. I did a master reset on my phone, didn't work. It wasn't until the Fuse was pulled and put back in that it worked. This is definitely not a quick and "simple" fix. The guys at Syncmyride had no clue to even pull the fuse when I called them today to let them know I fixed it. They said they would start incorporating it into one of the "normal" things to do to try and fix it.
