SYNC Frustrations....and Knowledge
On an unrelated note, I'll share a hopefully helpful tip regarding an issue I had with my SYNC. If you ever try to call someone on your contacts list, using the voice prompts, and get the "Calling Dot", or "Call Dot on cell, at home, at work, (etc)? It's because you've got either emoji's or punctuation hiding in your contacts on your phone, and it's throwing SYNC a curveball.
I fought that for months before finally discovering the problem. I went through every one of my contacts removing any punctuation or smileys, then re-synced it and voila! All contacts were voice dial-able again!
HTH,
Why would you have Smileys attached to peoples contacts anyway?
You must have a tweenie daughter creating contacts for you or something...right?
Also have voice recognition loops that suck. Sometimes I'll give it a command, and it will read it back to me and ask for confirmation, which I give, and then it just loops through until I turn off the car and turn it back on.
Wife's 2012 Focus has it and every now and then I push the wrong button and the woman just jumps out of the dashboard and starts hollering "SAY A COMMAND!!!!"..
Then she starts HOLLERING ALL THE COMMANDS in her arsenal...
Evidently STFU is not in her vocabulary...
Where is the fuse for that effing feature?
BTW, the hands free bluetooth in that FOCUS is worthless over 40 MPH. It sounds like the driver is hanging their head out the window in the wind along with the microphone at 70 when it is actually silent inside the car.. Ford can't fix it - they have tried a couple of times.. Hint - it's not the iPhone which works perfectly in other bluetooth vehicles we have had..
Does your wife's Focus have MyFord Touch or a standard radio?
The reason I ask is the MyFord Touch system will allow you to turn on an advanced interaction mode. When this is on, you do not get all the available command options:
Voice Control Command Categories | MyFord Touch | Ford.com
Jaclyn
Jaclyn
How can I disable sync altogether? Or should I just put some duct tape over the button to keep it from being pushed like I did with the Sirius button on the dash?
Black duct tape is like the dark side of the force.. It's so strong, it's evil..
How to Perform a Master Reset | SYNC & SYNC with MyFord | Ford.com
Jaclyn
Jaclyn
Either that or remove / duct tape the button.. I don't like a car that nags me.. If my new truck does the same thing, I will be disabling it as well.
Help me get back to basics here....
Along with a few other things - Electronic Fuel Injection, air bags and ABS is all good. The rest I can pretty much do without..
Thanks!
Thanks!
Jaclyn
LOL. I don't want it broken - just disabled because outside of the hideous hands-free microphone quality, it is the one part of this vehicle that annoys the heck out of me - and I know I am not alone....
Give me the option of turning Sync OFF Ford...
www.Social.Ford.com
Jaclyn
