57 Dash Gauge Problems
Old Jul 17, 2004 | 11:23 PM
captnmike's Avatar
captnmike
My fuel and temp gauges always read over the F anf H. I read that the voltage regulator could be at fault - where is it? Don't see it.
Old Jul 18, 2004 | 06:45 AM
manglass's Avatar
manglass
Hi,
Try connecting a test light in series with the fuel sender. It should blink with the key on. If it doesn't, then the IVR (Instrument Voltage Regulator) is faulty. It should be on the back of your instrument cluster. IIRC, it's a small "box" maybe 1/2' by 1" with 2 studs. If you need more help, let me know and I'll check the shop manual.
Lou
Old Jul 18, 2004 | 09:19 AM
57_ford's Avatar
57_ford
That voltage regulator is located on the back side of the guage panel rite under ware the speedo cable hooks up.
Old Jul 19, 2004 | 02:33 AM
Col Flashman's Avatar
Col Flashman
Unhappy
Capt.
It could also mean the either the Gauges or Sending units have gone bad or you've developed a Short in your wiring harness.
Cheers
Colonel Flashman
Red '58 Mercury M-100 w/223 I-6 & Merc-O-Matic
