Compression Test
Old Jul 27, 2014 | 02:20 PM
Eric Kropp's Avatar
Eric Kropp
Compression Test
So, acting like I was working on a gas engine I removed all the injectors to do a compression test......then did some reading and saw that you remove the glow plugs! Duh! OK, so now I am putting the injectors back in and just want to make sure I dont need to reconnect the injector lines....I plan on replacing all the injectors and getting the pump rebuilt if it passes the compression test.
Thanks,
Old Jul 27, 2014 | 03:31 PM
madpogue's Avatar
madpogue
I've never heard of a gas engine where you remove the injectors for a compression test....
Old Jul 27, 2014 | 04:06 PM
Eric Kropp's Avatar
Eric Kropp
I was using the injector as a comparison to the spark plug.........and since you didn't answer my question, I see you are not interested in helping, just looking to be a ...........................
Old Jul 27, 2014 | 07:45 PM
ihateminimumwage's Avatar
ihateminimumwage
You should be fine, as long as the IP's FSS has its wire disconnected. Still might squirt a little bit of residual fuel.
What compression tester are you using?
Old Jul 27, 2014 | 08:47 PM
Eric Kropp's Avatar
Eric Kropp
I used a K-D Tools Diesel compression gauge. Had over 450 psig on every cylinder but one. And bummer, it had 220 maybe, and it took five go-rounds to get that. I put a couple tablespoons of 15-40 in and it only came up like thirty pounds. I see the head coming off and getting that one touched up. Kind of adds up since you could hear it do the "woof, woof" real loud some times in the morning. My daughter called it the death shake! I thinking of using RD-IDI to get the new pump and injectors. There was one other company that I was reading about that said they sleeve the cylinder that the advance piston functions in. This sounds like a good practice. Any suggestions on that subject?
V-465
Old Jul 28, 2014 | 02:02 AM
ihateminimumwage
If you have an air compressor, pull the valve covers and loosen the rockers so the valves close. Run air into the glow plug holes with a rubber tipped nozzle, and pay attention to where it gets out of that cylinder. Air out of intake is intake valve, air out of exhaust is exhaust valve, air out of crankcase is rings.
Old Jul 28, 2014 | 06:26 PM
Eric Kropp's Avatar
Eric Kropp
When I pull the rocker cover I will have a look. I am hoping for a broken spring I can just replace. All the other cylinders were up near 500 psig.
V-465
Eric Kropp's Avatar
Eric Kropp
V-465
Old Aug 10, 2014 | 12:27 PM
Eric Kropp's Avatar
Eric Kropp
So I have a little more information on the low compression. I pulled the rocker cover an the third valve from the fire wall on the passenger side has a broken bolt that holds the rocker arm down. Thinking I've stuck the proverbial fat hog, I was pretty happy. Then the more I think about it....should that cause low compression? I can't process that much stuff in my brain right now. It would be quite coincidental that the cylinder with low compression also had the broken bolt and the two are unrelated. But stranger things have happened I suppose. I suppose the thing to do is put a new bolt in both the exhaust and the intake and do another compression test. I'll get a couple new bolts on Monday and run through the motions again.
V-465
Old Aug 10, 2014 | 02:08 PM
Eric Kropp's Avatar
Eric Kropp
I put an after market grade 8 bolt in just to test compression and it's back up over 420 psig. now I just need to find out why the rocker 4th from the fire wall is so loose. Bent pushrod? Lifter not pumped up?
V-465
Old Aug 10, 2014 | 03:56 PM
ifrythings's Avatar
ifrythings
For the loose rocker, its more then likely just a lifter not pumped up but you can easily remove the push rods. Just undo the two bolts holding the rocker pair down and pull the push rods out, do keep in mind the push rods do have a copper colored end that goes on the rocker side, more then likely it wont look like copper now but that end is different from the lifter side so just make sure you put them back in the same way.
You can build full oil pressure just by cranking the engine over (remove glowplugs to make it easier on the starter) to see if the lifter is just leaked down.
axel 56
19
May 14, 2011 10:05 PM
AndysFords
Aug 30, 2009 05:59 AM
parrisw
22
Nov 25, 2008 08:10 AM
richardmiller
Mar 20, 2008 06:39 PM
