brake caliper stuck
Old Jul 27, 2014 | 12:02 PM
gbeach's Avatar
gbeach
brake caliper stuck
1993 f250 7.3l 4wd. Yesterday my right front brake caliper stuck and it started smoking. I stopped for 20 minutes. and it went back to normal except the brake pedal was almost going to the floor and barely stopping. I replaced the brake master cylinder about 1 month ago, and all was fine til the caliper stuck.
I can replace the caliper, I just can't figure why I lost my brake pressure.
Old Jul 27, 2014 | 02:35 PM
Cpdenton's Avatar
Cpdenton
Brake Fluid Flush
Pretty good info about boiling the brake fluid in the first couple paragraphs.
Old Jul 27, 2014 | 03:53 PM
gbeach's Avatar
gbeach
wow, thanks for the help
Old Jul 27, 2014 | 04:29 PM
Cpdenton's Avatar
Cpdenton
So, looks like you got it hot enough to boil your fluid. Replace the caliper and bleed it out and you should be ok.
That help any more? Hope you get it fixed.
Old Sep 17, 2014 | 06:30 PM
genscripter's Avatar
genscripter
After reading this and other threads, I'm still not sure which brake fluid to use in my 1988 ford van (DOT3 or DOT4), or how much?
Old Sep 17, 2014 | 08:49 PM
Macrobb's Avatar
Macrobb
I just used whatever was handy; probably a mixture of both. Amount wise, enough to fill things to the top mark. If you get one of the larger bottles, it should be enough.
I'm pretty sure the 'right' stuff is dot-3, though.
Old Sep 17, 2014 | 09:53 PM
tecgod13's Avatar
tecgod13
DOT3 and DOT4 brake fluid are compatible with each other. It doesn't matter which you use, and they can be mixed with no problems. DOT4 has a higher boiling point, so could be considered better, though its not a large difference.
DOT5 on the other hand is completely different, and can't be mixed into a system that has DOT3 or DOT4. It can be used if the entire system is being replaced or completely cleaned out. DOT5 can be found in some motorcycles and collector cars. Its often used in restorations as it doesn't absorb water so won't cause corrosion in brake systems that sit for long periods of time. It also has the benefit of being safe for painted surfaces, as DOT3/4 fluids will destroy paint.
Old Sep 17, 2014 | 10:16 PM
genscripter
Awesome info. I want to do a full flush, so I'll see if I can find some colored fluid to verify it's completely flushed thru each bleeder. I did this on my Jetta TDI with some blue pentosin, and it's great to see the blue reach the end of the lines.
I had a caliper temporarily lock up on me today on the van. From reading other brake threads, I'm going to replace the calipers, pads, hoses, and fluid. Hopefully that will fix any future lock-ups.
Old Sep 17, 2014 | 11:32 PM
bduemig's Avatar
bduemig
I had a front caliper lock up momentarily several times a few months ago. Just before I purchased a new caliper, I noticed a clean spot on my coil spring. I looked closer and noticed the brake line going to the caliper was too close to the coil spring. It turned out the solid part of the line going into the caliper was bent causing the line to slip into the spring so when I hit a bump when in a slight turn, the spring would pinch the line setting that caliper until I stopped the truck and the line would then slip out of the spring. If I hadn't noticed the clean spot on the spring and the line, I would have never figured it out.
Old Sep 18, 2014 | 11:53 AM
genscripter
That's good to know
Old Sep 18, 2014 | 04:02 PM
Perk85F250's Avatar
Perk85F250
If you rebuild the caliper be sure to use metal pistons. I think rebuilt calipers come with metal pistons, not 100% sure though. Flushing the brake fluid every few years is good preventive maintenance. Hmm... I need to do that now that I think about it!
Old Sep 18, 2014 | 04:10 PM
genscripter
I ordered a Motorcraft caliper kit and hoses for both wheels, Amazon prime. I need the van on the weekend so I need to fix them asap. I hope the motorcraft caliper is up to par.
Old Sep 18, 2014 | 06:07 PM
tecgod13's Avatar
tecgod13
Why do you say metal pistons? I'm curious....
I would say the plastic (phenolic?) ones might be better as they won't corrode like metal ones would. Perhaps they won't conduct the heat as well, which I think would also be a benefit (isolating the pads from the fluid).
Old Sep 19, 2014 | 10:14 AM
genscripter
I have a question. When I take the hoses off the caliper and brake lines, is there anything I need? Are there seals in there that I need, or does it just compress tight? I haven't received my new hoses in the mail yet, so maybe they will have the seals or whatever I need, but I don't know.
Old Sep 19, 2014 | 11:18 AM
Perk85F250's Avatar
Perk85F250
Yes, phenolic pistons look good on paper when you compare them to metal. My experience however has been that in time they become groved by the o-ring and sieze in the caliper because they don't slide in/out freely. Ford used phenolic pistons for a few years but went back to metal pistons in the mid 90s. My 85 came with metal pistons, I rebuilt using phenolic, had issues a few years later, rebuilt again using metal about 10 years ago, no problems since.
