DIY S300/S366 Thread
Old Sep 23, 2014 | 11:32 PM
  #61
ReBilld's Avatar
ReBilld
Originally Posted by OldWoodsDiesel
follow-up question for Bill and Tyler:
looking through tube and pipe fitting charts - 1/2" AN (37 degree flare) fittings have an effective pass-through diamter of .39" in the fitting itself. compression fittings (as Bill used) have a nominal .400 pass-though diamter. i guess that's why the kits use 5/8" fittings, which have a nominal pass-through diamter of 0.48 in AN fittings.
So, Tyler, do you recall what the thread size/fitting connection at the turbo drain itself was? it seems like it'd be really tough to fit anythign much above 1/2" pipe thread in that space.
edit: after some searching, looks like i may go with one of these two into a welded pipe fitting on my DIY turbo drain plate... McMaster-Carr or, if space dictates, a much pricier elbow version McMaster-Carr
I made the piece that bolts to the bottom of the turbo for the drain. If I remember correctly, it is a piece of 1/2" think steel with a hole drilled in it and tapped for 1/2" NPT and the two bolt holes. This whole thing is was tricky to get in. Had to put one of the bolts in the hole then put the fitting in then bolt it to turbo. Hard to explain without being able to actually show you.
Old Sep 24, 2014 | 06:10 PM
  #62
OldWoodsDiesel's Avatar
OldWoodsDiesel
I know exactly what you mean, actually! I've got my plate made and 45 degree fitting in hand. Been thinking of the same order of operation.
With my angled turbo,though I may get away with angling the 45 fitting and squeaking a socket cap screw past it.
Old Sep 24, 2014 | 06:44 PM
  #63
ReBilld's Avatar
ReBilld
I never really even thought about angling the turbo when I did mine. Every one I had seen was straight. I like the looks of it sitting straight, but it does make it harder to build the down pipe.
Old Sep 24, 2014 | 07:04 PM
  #64
strokin'_tatsch's Avatar
strokin'_tatsch
Mine is angled quite a bit. Downpipe was still a PITA because of how the dummy built the passenger side uppipe. You can see how far up it comes in the pic I posted before... I think I'm going to pull these and install Irate pipes.....
You did that wrong... A piece of 1/2" thick steel isn't thick enough to tap NPT threads in correctly....
Old Sep 25, 2014 | 02:31 PM
  #65
strokin'_tatsch
disregard. Didn't mean to post again.
Old Sep 25, 2014 | 10:12 PM
  #66
ReBilld's Avatar
ReBilld
Maybe it was 3/8" NPT....I'd have to go look. Either way it worked
Old Sep 27, 2014 | 05:06 PM
  #67
OldWoodsDiesel
Bill, I may be wrong, but I think that comment by Travis was a knock on my anti-npt stance from above :-).
If so, I deserve it!
My plan for the drain line now include 3/8" npt to 1/2 tube compression fittings. BUT I'll be drilling the pipe side of the fittings out to ~0.450 for extra flow. There's plenty of wall there to drill and this'll get me to the effective ID of 1/2" fittings. Kind of hack-ish, I know, but least effort from where I am now and there's really no pressure in these fittings so should be just fine.
Again, I guess we'll see.
Old Sep 28, 2014 | 12:45 AM
  #68
strokin'_tatsch
You're not wrong.
Old Oct 23, 2014 | 07:22 AM
  #69
OldWoodsDiesel
Some very minor recent progress on this part of the larger truck project, but might as well post some pics that I’ve taken.
Here’s my turbo oil drain fitting into the old fuel pump hole. It’s a ½” compression fitting going into an aluminum fitting made on the lathe. I’ll be running ½” tube from the turbo outlet drain to this fitting
I meant to take a picture of my sketch that I made the part to. If anyone wants that sketch, just let me know.
I also made up the drain fitting on the turbo, by welding a fitting to a plate and machining the gasket mating surface. Apparently I didn’t take a picture of that yet, though…
Old Oct 23, 2014 | 12:09 PM
  #70
cowmilker08's Avatar
cowmilker08
Maybe this was covered in another thread, but what color paint is that? I really like it!
Old Oct 23, 2014 | 12:42 PM
  #71
OldWoodsDiesel
shoot! now, i'm not sure.
its either this one: Eastwood Ceramic Engine Paint Quart Universal Aluminum
or this one: Eastwood Ceramic Engine Paint Quart Universal Cast Iron
but i bought it at the Eastwood store in Pottstown, here in PA, so i don't have my receipt in email form to check it against. i'll have to look at the can in the barn when i rememember. please hold!
Old Oct 27, 2014 | 06:31 AM
  #72
OldWoodsDiesel
ok - i checked the can at home. this is the paint i used:
it doesnt look much like the shade of grey in the picture, but i'm happy with it. it seems to be darn tough, though. i sprayed the excess in the gun on an old file cabinet in the barn. it was dusty and probably covered with years of grime, but the paint stuck quite well. i had to use alot of force with a screwdriver to get it to scratch after a week of curing.
i did use the optional 4:1 activator as well. they also have it in a catalyzed rattle can now, which would save on cleanup.
Old Oct 29, 2014 | 03:58 PM
  #73
OldWoodsDiesel
quick question for you all:
i got my T4 mount and uppipes tacked up over the weekend and had my welder-buddy tig them up for me today. they look SWEET, but he pointed out that the sections from the stock passenger side up-pipe were magnetic, whereas everything else was not. i.e., my new bends and the driver's stock pipe were stainless, and the driver's one was plain steel, or a magnetic (lesser) alloy stainless.
i'm pretty sure the passenger side up pipe was not a replacement on this engine, but really have no way of knowing...
pics of the finishing product coming soon!
Old Oct 29, 2014 | 04:46 PM
  #74
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
So what's your question. Mine were the same way
Old Oct 30, 2014 | 06:31 AM
  #75
OldWoodsDiesel
i guess there was no question there, more of a statement. i checked my other engine last night. it was the same way. the passenger side on both was definitely rustier as well. not pitted rust anywhere like if it were plain steel, but its definitely a lesser grade of stainless over there. i wonder why...
