Expedition, IACV change
Old Jul 10, 2003 | 10:48 PM
bigfishford's Avatar
bigfishford
Question Expedition, IACV change
I believe I have a bad IACV on my 2000 Expedition. I have to drive with one foot on the brake and another on the gas to keep it from stalling due to low RPM. No engine lights or codes come up at all. Sometimes it runs perfect. Usually in the morning it is bad. Can anyone tell me how difficult this is to change? It looks like you need to be Gumby to get behind the IAC to exchnge it?
Old Jul 10, 2003 | 11:01 PM
BigMattXXL's Avatar
BigMattXXL
First off, welcome to FTE
The IAC does require a bit of gumby-ness to change, but it's not impossible. I've got big fat hands with little stubby fingers, and I changed it out in about 30 minutes.
XXL
Old Jul 10, 2003 | 11:05 PM
PaulC's Avatar
PaulC
I have a 1999 4.6, and once you unbolt the plastic "4.6" cover over the induction system, it's a matter of unplugging a two-wire harness and undoing two small bolts to have this little PITA in your hand.
I understand the 5.4 is a little tougher to access.
Old Jul 11, 2003 | 06:40 AM
bigfishford
Thanks for the quick reply! Now, I just have to find a replacement part. Any recomendations, or is this a dealer-only type of part?
Old Jul 11, 2003 | 08:00 AM
buzzard's Avatar
buzzard
I couldn't find one at local parts stores, but have heard that NAPA might carry it....give one a call. Ford dealerships definitely have it for around $65.
Old Jul 11, 2003 | 08:38 AM
shakespearesdad's Avatar
shakespearesdad
I thought I was quite the mechanic until I bought my Expy! I don't even know what an IACV is. Fortunatly it's new and under warrenty.
I will be the first to download BigMatt's info!
Old Jul 11, 2003 | 08:46 AM
Bobby Reynolds's Avatar
Bobby Reynolds
Your Expy is a special creature and by becoming the caretaker of one, you are now no longer a mere mortal mechanic....
Old Jul 11, 2003 | 09:24 AM
Bobby Reynolds
Is this also known as the "idle speed control" ? I was looking for it on fordpartsonline.com and it's the closest that I can find. It's about 60 bucks.
Bobby
Old Jul 11, 2003 | 09:35 AM
Phil056's Avatar
Phil056
It's actually known as the Idle Air Control Valve.
I've seen them for around 80 bucks or so online.
I couldn't find them at NAPA online though.
Good Luck
Old Jul 11, 2003 | 02:04 PM
PaulC's Avatar
PaulC
Just be certain to disconnect the battery as the first step in the removal/installation process.
Old Jul 11, 2003 | 02:16 PM
Bobby Reynolds
Really? Why is that? (just curious)
Old Jul 11, 2003 | 02:25 PM
PaulC's Avatar
PaulC
As per Ford's Service Manual.
In this case, the engine computer has to become reacquainted with the new IAC. Disconnecting and reconnecting the battery will trigger this learning process.
Of course Ford, being hyperconservative, would suggest that the battery must be disconnected before putting air in the tires if they could get away with it...
Old Jul 11, 2003 | 04:58 PM
buzzard's Avatar
buzzard
Ain't that the truth. I wish I had a dime for every time Ford recommends disconnecting the battery before a procedure.
You don't necessarily have to disconnect the battery before starting the IAC valve replacement, but like Paul mentioned it is wise to reset the PCM immediately after replacement/before starting it back up so the PCM can "re-learn" with the newly installed component.
Old Jul 11, 2003 | 07:50 PM
verbal kint's Avatar
verbal kint
If you have an Oreilly store near by call them. I work at one in Houston and we don't keep them in stock but our wharehouse does which means that we can get them same day or next day. If I remember right the Motorcraft part number is CX-1877 and I think that it sells for a little under $60. Hope this helps you guys.
Old Jul 11, 2003 | 09:47 PM
buzzard's Avatar
buzzard
Funny, my neighborhood O'Reilly told me it was a dealership only part.
