the dreaded fuel pump
Old Jul 25, 2014 | 01:54 PM
cagedog's Avatar
cagedog
Starting a new thread because I seriously need help.. 1988,f-superduty.. 7.5 ..Fuel pumps not working.. Found a problem with the ground on EEC. Made everything work.. Parked for a couple weeks..now nothing.. All fusable links are good...relays are new.. Grounds all seem to be good.. Grounding pin 6 on obd test port will not bypass fuel system .. The shut off switch has no power...but both pumps have 12 volts.. Fiddling with wires and probing everything related made pumps come on briefly.. 2-3 seconds...now nothing.. Wire nightmare and can't find the culprit...any help would be appreciated
Old Jul 25, 2014 | 01:57 PM
cagedog's Avatar
cagedog
Currently have no power to fuel injectors.. And only one wire is hot on each relay
Corey Beckwith
1997 - 2003 F150
Apr 29, 2016 07:40 PM
mecsey33
Dec 28, 2012 02:16 PM
turbozeke418
Jan 24, 2006 06:30 PM
grim
Electrical Systems/Wiring
May 22, 2003 10:04 PM
plaisted
Oct 30, 2002 10:12 PM
