1978 - 1996 Big Bronco
Ball Joint grease
Old Jul 10, 2003 | 08:50 PM
Sudsrat's Avatar
Sudsrat
Ball Joint grease
Recently had upper and lower ball joints installed.Greasable.How
often should they be regreased,and how can you tell:
a)When they need regreasing?
b)When they are full?
I will be using the white lith.
I do quite a bit of off-roading on the beach.
Old Jul 11, 2003 | 01:58 AM
steve83's Avatar
steve83
Ball Joint grease
Don't use white lithium on anything but door hinges & the like. For the ball joints, u-joints, & other hi-load spots, use ONLY hi-pressure grease, preferrably hi-temp, too (disk brake wheel bearing grease). Never use boat trailer grease - it won't take the heat. They're full when grease squirts out the seals, and they need grease whenever you get back from dunking them or ~30,000 miles.
Old Jul 11, 2003 | 04:36 AM
Sudsrat's Avatar
Sudsrat
Ball Joint grease
Thanks Steve,guess I was misled about the white lith.
Steve
seuadr
Dec 25, 2013 08:03 AM
69Bronc
Jan 28, 2013 10:26 AM
fdude64
Feb 10, 2011 10:16 PM
steve(ill)
1997 - 2003 F150
Jul 31, 2005 10:10 PM
