2000 Ford explorer engine swap help.
Old Jul 23, 2014 | 10:32 PM
F100trauma's Avatar
F100trauma
Need a little help here guys! So I bought this engine out of a 2000 explorer 5.0 to put in my 77 F100 this engine is going to get fuel injected using all the components out of a 1990 Mustang, now I just need to know which components out of my old 302 I'm gonna need to move to the new engine besides the obvious ones like timing cover, water pump harmonic balancer and power steering and alternator bracket,
so is there anything else that needs to transplanted to the new engine?
Old Jul 24, 2014 | 12:07 AM
oddfordjunkie's Avatar
oddfordjunkie
Don't know which style frame it's going in but that oil filter mount may need changed.
Also the motor mounts but that falls in the obvious list.
That's about as much as I know about little V8s.
Old Jul 24, 2014 | 03:27 AM
0ldman's Avatar
0ldman
The 77 and 90 will have different balances. The harmonic balancer will not swap. You will need the 90 balancer. Not sure if the crank pulley will bolt up to it.
Old Jul 24, 2014 | 09:47 AM
F100trauma's Avatar
F100trauma
Well that sounds problematic! I will do some research on that issue and see what I find.
Old Jul 24, 2014 | 10:24 AM
F100trauma's Avatar
F100trauma
Well after talking to a budy of mine he told me all that I have to do was get a 50oz balancer that will accept my pulley and.problem solve, and summit sells one at a pretty good price or maybe I can find one at the salvage yard will see.
Old Jul 24, 2014 | 02:28 PM
emeraldcoupe's Avatar
emeraldcoupe
being that your engine has the gt40p heads, the spark plugs are angled different than the standard sm blk heads. your stock exhaust manifolds may not clear all the plugs / wires. not sure if you can use the explorer manifolds on your truck or not.
Old Jul 24, 2014 | 02:57 PM
0ldman's Avatar
0ldman
He's right.
Forgot about that. I'm going with old 351W heads to get around that problem on mine.
Old Jul 24, 2014 | 09:18 PM
F100trauma's Avatar
F100trauma
I will be using the manifolds that came with the new engine the GT40p ones, I will just have to take the truck to the muffler shop to have them route my existing exhaust in to the new manifolds.
Old Jul 24, 2014 | 09:22 PM
F100trauma's Avatar
F100trauma
I will use the manifolds that came with the explorer engine, I will just have to take the engine to the muffler shop to have them route my existing exhaust in to those new manifolds.
nolan62
Dec 31, 2017 09:23 PM
nitrain03
Jan 3, 2012 10:18 PM
jayton4
Modular V8 (4.6L, 5.4L)
Oct 9, 2011 12:08 AM
DJdemon6696
18
Jun 10, 2009 09:52 AM
Mudder
Apr 11, 2005 11:16 AM
