Need Help With Trailer Lights
Old Jul 23, 2014 | 08:17 PM
copsey's Avatar
copsey
Inconsistent connection through 7 wire plug and no taillights on four wire plug. Anyone seen anything similar?
Old Jul 23, 2014 | 08:27 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Dirty connection before the 7pin last time I did.
Old Jul 23, 2014 | 08:33 PM
copsey's Avatar
copsey
How do you mean? At the 7pin or is there a connector upstream?
Old Jul 23, 2014 | 10:12 PM
RavageX's Avatar
RavageX
Check you connector on both side. Mine had the tabs that hold the back side break off. I can push the connector together enough that it stays, but after a few good bumps on a long drive and it pops back out. I plan on replacing the entire assembly before I tow anything next time. If yours is broke like mine you could temp fix it with some super glue maybe. I think taking off the rear bumper makes it easier to get to also.
lbrauer
Feb 10, 2016 02:33 AM
dangerranger10
1983 - 2012 Ranger & B-Series
Jul 3, 2010 07:19 PM
MikeSDK
All Things Towing
Oct 4, 2006 11:26 PM
solomon
1997 - 2003 F150
Dec 16, 2005 03:30 AM
jwdenney2
All Things Towing
May 3, 2003 10:06 AM
