Replacement Choke Tubes
Old Jul 22, 2014 | 04:03 PM
dstraw's Avatar
dstraw
The PO has removed the "Choke Tubes" from my 74 302 2 barrel with climatic choke.
Where can I get a set of Factory tubes?
I have search the local pull-a-part no luck. Is everyone using the "Help" Choke Stove And Heater Tube Kit?
Old Jul 22, 2014 | 04:20 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I've made them from steel brake line. As I recall the parts catalog says to make from bulk material. I'll double check that.
There are two lines. The cold side goes from the exhaust manifold to the air horn of the carb. In the picture the nipple with the vacuum cap is where it connects to. The hot side goes from the exhaust manifold to the threaded fitting on the choke that kinda points down.
The hot side has an insulating sleeve that goes over it.
Old Jul 22, 2014 | 04:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I checked the parts catalog and it shows the outlet tube is D4OZ-9819-A. The inlet tube has the notation "make from bulk tubing". The outlet tube also uses an insulating sleeve part number 381490-S145A.
I checked both part numbers and no dealer or obsolete parts supplier has either.
This is roughly what the setup should look like.
Old Jul 22, 2014 | 09:24 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I did some digging. Mustangs Unlimited has reproduction lines for 302 2bbl Mustangs and Cougars. I don't know for sure if they'll fit a truck or not.
Plain steel is $21.95 and stainless is $29.95
http://www.mustangsunlimited.com/itemdy00.asp?T1=MUK1001+01&catkey=65-73$srccode=MUEMVWEB
EDIT: Copy and paste the link above. For some reason it didn't come through as a hyperlink.
Old Jul 23, 2014 | 11:45 AM
dstraw's Avatar
dstraw
Thanks Mike! How do the lines attach to the "stove" on the exhaust manifold?
Old Jul 23, 2014 | 01:37 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The manifold has a small chamber cast into it that is completely separate from the exhaust. The top of the chamber has a hole that the hot side tube is pressed in. It's a very light fit, you can push it in.
The chamber itself has a filter in it that resembles steel wool. The bottom of the chamber has a fitting that is pressed on to seal the chamber. In the side of this fitting is another hole that the cold side line goes in.
It all just presses together, nothing fancy.
If the old lines are broken off in the manifold, it's very easy to just drill out the broken pieces.
The filter and fitting are also reproduced and most Mustang parts dealers carry them.
Here's the filter and fitting.
Old Jul 23, 2014 | 11:00 PM
hermancm's Avatar
hermancm
That new carb sure stands out!
Old Jul 30, 2015 | 11:55 AM
bowtieman55's Avatar
bowtieman55
@dstraw, what ever came of this project? I'm at the point of figuring out a choke tube setup for my 360.
Old Jul 30, 2015 | 12:12 PM
bkaul's Avatar
bkaul
I can verify that these lines fit my truck - I used them when I was running a 2V carburetor. (Though I'm not sure of the history of the engine, so I don't know for sure whether the exhaust manifolds are original to the truck).
Rusty_S
Jan 29, 2016 11:52 AM
Dad&Son&F100
Feb 15, 2015 02:25 PM
Duke78
Feb 16, 2013 05:25 PM
mekanik23
Mar 20, 2008 04:07 PM
sfc11b
May 7, 2005 02:29 AM
