Parking brake problems
Old Jul 20, 2014 | 10:11 PM
tylerz71's Avatar
tylerz71
Bought a 92 f150 with 115k original miles. I like it so much I want to keep it for once. The parking brake is very weak and its a 5spd so it's pretty important. I am familiar with automotive systems and work with them every day but avoid drum brake work at all costs normally. The drums had the installation clips on so I assume they are untouched. They are glazed pretty good but the shoes have a ton of meat left. Is there a simple adjustment or should I put new drums on and see if its a bit tighter?
Old Jul 21, 2014 | 12:15 AM
JKNW's Avatar
JKNW
Brakes are out of adjustment, adjust em through the backing plate just like any other drum brake setup.
Old Jul 21, 2014 | 10:07 AM
tylerz71's Avatar
tylerz71
Alright. I searched more on adjustment and see where it is fairly common but many are replacing the cables too I guess it may be stretched, haven't even inspected those. Will report back
Old Jul 21, 2014 | 10:26 AM
DBD7's Avatar
DBD7
I have a 93 F250 and have now had both clips that attach the intermidate cable to the other cables Fail on me. I would double check those as well.
Cheap and easy install.
Dorman - Help Emergency Brake Cable Connector Assortment 21126: Advance Auto Parts
Old Jul 21, 2014 | 10:55 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Tyler
The cables could stretch but in most cases they become frozen (rusted) where they dip down coming out of the backing plate.
This is why people replace them.
If you have the drums off you can watch as someone else applies the parking brake.
Observe the equalizer bar on the drivers side frame rail too.
sandymane
Jul 19, 2019 06:56 PM
Diesel_Brad
May 8, 2012 04:29 AM
Philywilly
Sep 9, 2005 07:56 PM
Labmutt
Escape & Escape Hybrid
Nov 8, 2004 10:43 PM
cbmark
Dec 6, 2003 11:40 AM
