What the bloody hell... I can only assume it's the tires and the pressure is off. I'm going to talk to the wife and see if we can afford to go ahead and order 2 of the Treadwrights tonight. I know it's not much, but it's a start
Thanks for sharing your research. You said "... where I C ..". Did you mean there is a 'C' spring?
Yes, sorry I had a typo and didn't catch it. I chose my spring based on part number/specs and because I bought new ones from Ford I have no way to cross reference my pn to a spring code. Some have said the spring I went with is a C code but I have no way to confirm unless someone has a vin from an F250/350 that came from the factory with C codes. I can back track from there to an electronic bill of material.
No worries... I'm more than happy to take the help, typo's and all
1.5 to 2" of lift seems about right to level or lift the rear slightly higher. Anyone think I'll have to worry about drive shaft angle to the u-joint for that little bit of change?
My guess is that shouldn't have a problem. That much lift doesn't seem to affect the 4x4s. When I originally did my swap I also used the F250 block and the rear of my truck went up about 3.5". I drove it like that for about 200 miles and didn't notice any difference or any vibration.
