Help finding New Cruise Control Buttons
Old Jul 18, 2014 | 12:00 AM
jdq1986's Avatar
jdq1986
Using a DVOM on my cruise control servo plug I determined I need a new set acceleration button. Too much resistance between pins #5 and 6 with set-accel pressed. I think you have to get the whole setup (on/off and resume/set-accel/coast) to replace any of the above. I am however having trouble finding the part. I *think* it may be part number F2UA-9D780-BB but I'm not sure. Can anyone verify this? I'm driving from Dalhart, TX to Houston, TX tomorrow (10 hours minimum) so if I could locate the part somewhere between here and there that would be awesome.
1993 F350 Crew Cab Long Bed 7.3L Diesel, RWD, non-turbo.
Old Jul 18, 2014 | 06:12 AM
ncranchero's Avatar
ncranchero
Is your 93 button on the horn pad or signal stem?
SW5877 Motorcraft which is stem mounted. But that is dealer installed cruise.
SW5877 on eBay
SW5878 Motorcraft which is pad mounted w/o air bag
SW5879 is your F2UA-9D780-BB/F2UZ-9C888BA for the 94's
1997-94 w/Air Bag ................................................ SW-5890
1997-92 Dealer Installed ......................................... SW-5877
w/o Air Bag - Mounts In Horn Pad ............................. SW-5878
1994 F150/350; w/o Air Bag ..................................... SW-5879
Old Jul 18, 2014 | 07:44 AM
jdq1986's Avatar
jdq1986
They're mounted in the horn pad. So, you think it's the SW-5878? That one works for the '93?
Old Jul 18, 2014 | 07:52 AM
ncranchero's Avatar
ncranchero
Yes but nobody has any. I've not tried crossing the Motorcraft # back to a Ford #. Outwardly they "look" the same as the SW5879 but the wires are probably a bit different, not that it may not work for the SW 5878. Maybe someone else can answer that one.
Old Jul 18, 2014 | 07:55 AM
jdq1986's Avatar
jdq1986
Thanks for your help. I may end up having to call Ford to track one down. Hopefully somebody will have one somewhere not too far out of my way. With 20 hours driving and no cruise control I can feel at least one speeding ticket coming on.
Old Jul 18, 2014 | 02:25 PM
subford's Avatar
subford
Is this what you are needing?
F2UA-9D780-BB FORD CRUISE CONTROL SWITCH MOTORCRAFT SW-5879 F2UZ-9C888BA NEW
TimmyAbrams
1978 - 1996 Big Bronco
15
Feb 20, 2008 07:10 PM
manibusan
Electrical Systems/Wiring
Nov 7, 2006 04:26 PM
pfogle
Oct 26, 2003 01:02 AM
