Plugins Tucked Up In Frame
Old 07-17-2014, 10:37 PM
stydel311's Avatar
stydel311
stydel311 is offline
I found these 2 plugs tucked up in the frame on the rear drivers side near the bumper mounts. They're right next to where the tail lights plug into the T connector for the 4 pin trailer harness the truck has. Anyone have an idea of what they are for?
Old 07-18-2014, 12:20 AM
Crewcabber's Avatar
Crewcabber
Crewcabber is offline
Electronic brake controller is the smaller one and trailer light harness is the bigger one.
Old 07-18-2014, 12:26 AM
stydel311's Avatar
stydel311
Where do they come out at up front?
Old 07-18-2014, 11:00 AM
Phil Woolfson's Avatar
Phil Woolfson
Phil Woolfson is offline
Thy should be on the DS fenderwell.
Old 07-18-2014, 07:30 PM
stydel311's Avatar
stydel311
So can these plugs be used? Wouldn't they just plug into a 7 blade trailer harness?
Old 07-18-2014, 08:47 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,172 Likes on 926 Posts
If you could find the obsolete Ford adapter they would be plug-n-play. Otherwise it is cut/solder/shrink wrap time.
Old 07-19-2014, 12:30 AM
stydel311's Avatar
stydel311
The truck has a 4 pin pig tail installed now so I bought a 4 pin to 7 blade adapter.
Old 07-19-2014, 02:55 AM
Crewcabber's Avatar
Crewcabber
How is the 4 pin wired? Off of your tail lights? Rip it out go get a 7 flat blade not pin and wire it up its easy and there are diagrams all over the net to follow.
Old 07-19-2014, 04:51 PM
stydel311's Avatar
stydel311
The 4 pin adapter t's into the tail light harness. Here's something just like it on amazon:
Robot Check Robot Check
Old 07-19-2014, 05:34 PM
rla2005's Avatar
rla2005
rla2005 is offline
When I wired in a 7 pin trailer plug on my last 4 OBS trucks I used the tail light T - adapter then cut/spliced/shrink wrapped the wires from those plugs at the back of the truck. That way I kept the 4 - wire and 7 wire capability.
Jeremy5
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-03-2016 11:25 PM
bullnose1985
10-11-2015 11:12 AM
storchmj
03-17-2015 07:00 AM
DJandAmy
03-03-2014 01:29 PM
myklstrng
11-07-2010 10:46 PM
Quick Reply: Plugins Tucked Up In Frame
