Oil & Lubrication
Slick 50
Old Jul 17, 2014 | 01:53 PM
E Bjornstad's Avatar
E Bjornstad
Former Vendor
Slick 50
Back in my college days in the early 90s, when I didn't know an alternator from....a non-alternator, Slick 50 was pretty hot stuff. Then they went out bankrupt and got bought by Turtle Wax I think.
Old Jul 18, 2014 | 02:11 AM
351Cleveland C4's Avatar
351Cleveland C4
I tried a bottle of it one time in a transmission thinking it might help clean up a 170,000 mile unit. Now I know it's not fair to blame slick50 entirely, but that trans has been screwy ever since. I will NEVER EVER EVER use ANY slick50 product again.
Just my experience.
Old Jul 18, 2014 | 07:33 AM
pawpaw's Avatar
pawpaw
Slick-50 was acquired by Quaker State, then Pennzoil acquired those two, then SOPUS/Shell Oil Products US, acquired those 3, so Shell now owns Slick-50 & is looking for a buyer, you interested????? lol
Lets think some more about products that have solids in them & say on the container, "shake before using". Now if we use such a product in our vehicles, how are we to shake the vehicle up to get those solids remixed, before using the vehicle after an over night, or longer sit????? How do those particles know not so settle out & clog something important up, or not to imbed themselves into clutch friction material & alter its friction properties, or not to get into a really hot area like piston ring lands, melt & cause mischief ect, ect???? I'm not aware of one vehicle mfgr world wide that factory installs, or specifies products like this for scheduled maintenance. Perhaps these kinds of products are best left on the store shelf to gather dust?????
Old Jul 18, 2014 | 08:06 AM
BoKnowsDiesel's Avatar
BoKnowsDiesel
Former Vendor
Well if you're looking for an additive... I may be able to help ya out
Old Jul 26, 2014 | 03:58 PM
retiredsparky's Avatar
retiredsparky
Years ago I tried Slick50 in a motorcycle and a Mazda truck. Both vehicles had valve noise not long after adding that crap to the oil. Solved both vehicle's problems by changing the oil!
Old Jul 26, 2014 | 05:48 PM
Tedster9's Avatar
Tedster9
There's all kinds of oil additives, and they are added by the oil companies. Teflon is overrated anyway, give me a good cast iron pan anytime. My rule is simple, if pilots won't put it in their plane, I won't put it in my truck.
Sent from my iPhone using IB AutoGroup
Old Jul 26, 2014 | 06:35 PM
351Cleveland C4
Good rule. I kinda go by that too. If it's good enough for a plane or a big rig, it's good enough for me.
Old Jul 26, 2014 | 11:34 PM
dkf's Avatar
dkf
You have to watch it. A lot of products out there do more harm than good and are really more for keeping a clunker on the road for a few months until you can get something better.
Old Jul 28, 2014 | 09:30 AM
BoKnowsDiesel
Former Vendor
I think there are a lot of "snake oils" out there, but there are products that will do a whole lot of good. That is where you just have to do your research and figure out what products (if any) are good for your vehicle
Old Aug 1, 2014 | 07:39 PM
cparks's Avatar
cparks
There is even more than that. They were sold a few years ago to ITW among the 800 other companies they own.
Only thing I would use is Rislone. It is a good cleaner, and keeps the engine clean. Been around almost 100 years.
Old Aug 13, 2014 | 10:49 AM
speakerfritz's Avatar
speakerfritz
dupont, the inventors of Teflon (the key ingredient in Slick50) is on record not reccomending "Teflon" for use in oil passages of engine.
aside from that...there has always been a suspension problem with oil additives...they wind up at the bottom of the oil caontainer or the bottom of the oil pan.
newer technology use of things like Moly in products like Mobile 1 0W30 racing and 0W50 racing involve particles that suspend in oil very well.
Old Oct 2, 2014 | 10:57 PM
Oldchap's Avatar
Oldchap
Don't know if Slick does anything at all, but their demo engine at the County Fairs, was the only time I ever saw an operating crankshaft on a running engine, with the oil pan removed, to demo that an engine treated with their product could run without oil. Knowing County Fairs, it might have been a trick, but it was impressive!
Old Apr 8, 2017 | 10:11 AM
Eric dee's Avatar
Eric dee
Slick -50
Just my experience.
I'am laughing right now, after reading your post, I did some shopping at the local Wally mart and ran across the "Slick-50" on the shelf, it's been a couple of decades since I've seen the stuff,never payed attention to it. Back in the day that stuff was outlandishly expensive, now it's less than $20 bucks a bottle,never used it, but curious if the junk is any good???. Maybe I'll put some in my lawnmower, run it for a few minutes, drain the oil sump, and mow my lawn without any lube in the crank case and see if it hold up...lol
Old Apr 8, 2017 | 05:46 PM
speakerfritz
The original slick 50 was an add to fresh oil, drive for 20 minutes, then drain and refill the oil. Ideal was what ever particles that did not bind with the metal needed to come out.
however, mean while, dopont, the patten holder for tpfe, or teflon, was on record saying they did not recommend tpfe to be used as an engine oil additive.
there are a lot of oil additive today that are sub 1 micron in size and will bound to metal porous with out clogging oil filters. Ptfe is not one of them.
in the transmission world, there is only 1 transmission additive that claims compliance with oem standards and that's lubeguard. Lubeguard comes in 4 flavors. Silver which is a universal blend that claimed to work in all transmissions. There is a green, black, and a red version. The reversion is the one compatible with recent year ford fluids. The stuff is basically whale fat, which is an excellent metal lubricant .
but if your transmission is worn and your fluid is not red anymore, we all heard the stories of functional transmissions crapping out once you change the fluid...this is because the friction plate particles in the fluid was the only thing keeping the tranny from slipping.
Old Apr 9, 2017 | 09:26 PM
Beechkid's Avatar
Beechkid
and they were sued years ago by the FTC for advertising fraud, they actually tried to defend themselves in court and failed terribly...IIRR.................just more
newguy399
May 17, 2015 01:59 PM
Knotwild
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 14, 2009 03:03 AM
Griesel
Apr 27, 2006 06:17 AM
Medic911
2004 - 2008 F150
Mar 29, 2004 09:47 PM
ddurant
16
Jun 27, 2003 01:09 PM
