What is this wire for?
Old Jul 10, 2003 | 11:05 PM
pdsq89f150's Avatar
pdsq89f150
I have an 89 F-150 5speed with a 300 and I'm trying to figure out why my battery keeps draining overnight. There is a wire on the main engine wire harness that is frayed and broken. It is located on the driver's fenderwell and it's in the harness that is closest to the rear of the vehicle of the three that are there. The wire is black and it's in the pin that is 2nd from the right one and on top. I have attatched a link to a picture of it (kind of sucks, but hopefully someone can figure out what I'm talking about). What does this wire do? There are a few things that don't work in my truck, maybee it could be for those. As always, thanks for any help someone can give me.
Old Jul 11, 2003 | 06:32 AM
pdsq89f150's Avatar
pdsq89f150
Here's a link to the picture. sorry
http://forums.stangnet.com/attachmen...achmentid=1541
Old Jul 11, 2003 | 09:31 AM
steve83's Avatar
steve83
What's the TRANS code from the door sticker: "E"?
Since the connector isn't plugged in, I doubt that's the problem, but Dennis (Mil1on) has posted a procedure for tracing a drain several times, so do a search in the electrical forum.
Old Jul 11, 2003 | 04:41 PM
javi2001's Avatar
javi2001
Please double check what color is this wire, maybe you will need to remove a couple inches to uncover more wire and look the real color.
After that I can tell you what is this..
Regards;
Old Jul 11, 2003 | 05:29 PM
rustyolred27's Avatar
rustyolred27
I think it is the alternator wire. it is a wire that runs from the alternator to your vehicle accessories, to keep them from running off of just the battery.
Old Jul 12, 2003 | 12:10 AM
pdsq89f150's Avatar
pdsq89f150
I unplugged the connector to show you what wire it was. I think it's black, or just really dirty and it has a buldge like it's a fuseable link or something. It's on the other side of the engine as the alternator and the alternator seems to work fine. I think it might be something with the cruise control or possibly a fuel guage or something like that because neither of those two work.
Steve83: Not too sure on the door code since I don't think the sticker is there anymore. I think it has the mazda 5 speed though.
I was just trying to follow those wiring diagrams in the Hayes manual and I don't understand which of the 7 diagrams to even look at.
Old Jul 12, 2003 | 12:28 AM
pdsq89f150's Avatar
pdsq89f150
Steve83 thanks for telling me about that article. I now have a pretty good approach at finding this short. Can I just hook up a volt meter between the battery terminal and the wire? Or do I need a test light or ohm meter?
Old Jul 13, 2003 | 04:30 PM
steve83's Avatar
steve83
A multimeter is the best investment. It can read voltage, resistance (Ohms), and can act like a test light (diode test buzzer). Without knowing what the circuit is/does, I can't tell you what to test for.
Old Jul 17, 2003 | 09:02 AM
t4kne's Avatar
t4kne
It may not be a short, it may be a legitimate load from something always on. I found my battery to always be weak after sitting overnight. Turned out my glove box light was staying on all the time. Faulty swtich. With a short ride to work and back, the battery was slowly dying. Could also be your brake lights stick on because of a faulty brake switch.
Scope04
Jan 10, 2017 08:16 PM
Glaser67
Sep 8, 2016 09:22 AM
awhtx
Jul 23, 2016 05:19 PM
thomas445672
Jun 13, 2016 06:54 PM
jstsumgi
Sep 14, 2015 08:57 AM
