Sponsored by: Auxito
Muffler Bracket Suggestions
Old Jul 16, 2014 | 07:01 PM
Shernius's Avatar
Shernius
I just bought a Walker 18577 SoundFX muffler and it doesn't have the bracket on it my stock 1999 muffler does. I could just rig something but would like to see what others did to support their exhaust by the muffler. I obviously want something durable and would work as well as the original.
I don't have a welder readily available.
What did you do?
Old Jul 17, 2014 | 08:42 PM
steve(ill)'s Avatar
steve(ill)
buy a 5/16 rod at the hardware store. bend it to look like the original rod that is welded to the muffler, but make the new rod lay against the exhaust pipe. Add another muffler clamp around the exhausts pipe that clamps the 5/16 rod tight to it.
Old Jul 18, 2014 | 05:39 AM
Shernius's Avatar
Shernius
You know, that's exactly what I was thinking of doing. The rod is U-shaped with two insulators so I was going to bend up two sections and clamp them to the tail pipe section. Then when I got a hold of a welder I was going to weld them to the pipe or most likely the clamp.
Steve, is 5/16s the same size as stock to fit into the holes of the insulators? Things are a bit crusty down there and I can't get an accurate measurement.
Old Jul 18, 2014 | 11:30 PM
steve(ill)'s Avatar
steve(ill)
I really don't know the dimension. From crawling down there over the years, it just seems like 5/16 is about right. Take a 5/16 bolt and crawl down there are compare by visual....I think that's close.
V10man
Modular V10 (6.8l)
Nov 3, 2014 04:45 PM
DaveMac2Vans
Aerostar
Mar 8, 2009 01:47 AM
adipose
Apr 9, 2008 02:44 PM
spitball
13
Oct 28, 2005 06:11 AM
tealboy1
Apr 28, 2002 03:49 AM
