air horns
Old Jul 10, 2003 | 12:48 PM
dandep's Avatar
dandep
air horns
I want to install air horns on my 2000 X. I can't for the life of me find the origal horns. I can feel and hear them near the front passenger side, near the head light. I removed the battery and washer reservoir. Nothing
Anyone know where it is located.
Thanks in advance for any help
Old Jul 10, 2003 | 01:28 PM
gmyers's Avatar
gmyers
air horns
You are in the right area. My stock horn was between the fender and the firewall, under the battery. I had to remove the wheel shrouding from the tire side, to get to mine.
Old Jul 10, 2003 | 01:32 PM
dandep's Avatar
dandep
air horns
Thanks for the responce. I was looking at the shrouding and I said to myself i bet I will have to take that off. It was 96 degrees out and I said I'm not going there now. Thanks for your help.
Old Jul 12, 2003 | 05:35 AM
1bigford's Avatar
1bigford
air horns
Let us know what horns you go with, I/m thinking of doing the same.
Old Jul 12, 2003 | 08:31 AM
offroadjunkiex's Avatar
offroadjunkiex
air horns
hey. I work for the railroad and am in the process of aquiring a set of freight train horns for my x. will sit down inside my roof rack to hide them a bit.
Old Jul 15, 2003 | 06:15 PM
76Econoline's Avatar
76Econoline
air horns
offroadjunkiex, keep in mind that train horns are illegal to use on public roads in all 50 states, as they are too loud at their design pressure. If you do use them, be sure to keep your air supply below about 75 psi. BTW, which one did you get?
Old Jul 15, 2003 | 07:46 PM
offroadjunkiex
air horns
yea i know about the laws i would only use them out in the middle of no where messing around. they will be hidden in the roof rack. I am putting a 7 in lift with 37s so they wont be easy to see. I think he has k5la for me. Have not got it yet.
Old Jul 16, 2003 | 11:58 PM
JoeBoost's Avatar
JoeBoost
air horns
Rickerson truck supply sells the entire kit to install a airhorn on your rig, and i believe they sell train horns as well. I put a 3 foot International horn on my X , and hit it with 120psi, sure gets peoples attention
Old Jul 17, 2003 | 07:28 AM
76Econoline
air horns
Cool...the kl5a is a great sounding horn!
And an air horn is just the right touch for an X, isn't it?
Old Jul 17, 2003 | 05:46 PM
offroadjunkiex
air horns
true train horns are expensive. hard to get check out ebay and you will see used ones go for 350 and up.
Old Jul 22, 2003 | 07:32 PM
offroadjunkiex
air horns
I just got a set of Nathan AirChime k5h horns. you can see them here and here them here
Old Aug 1, 2003 | 07:04 PM
offroadjunkiex
air horns
well here are the horns
http://www.superford.org/registry/vehicles/detail.php?id=2147&s=10268#content
dmallen
Jan 10, 2016 08:52 PM
bill2298
Jan 13, 2015 07:51 PM
Fordman96
Dec 6, 2014 02:08 PM
Blue94Bronco
1978 - 1996 Big Bronco
Oct 6, 2012 06:55 PM
BAJI26
Aug 2, 2008 08:19 AM
