dana 44
Old Jul 17, 2014 | 01:15 AM
moonley's Avatar
moonley
Originally Posted by slowrollerzcustoms
im building off a 2wd frame but have my 4wd frame to fabricate the 2wd into a 4wd im trying to figure out if my front suspension currently on my 78 will bolt up to the 77
No, a 4x4 suspension will in no way bolt up to a 2 wheel drive frame. You would be much better off using 4x4 frame, and if you want a dually converting the axles on the 4x4 frame.
There are a LOT of threads on here about 4x4 conversions, do some searches and you'll begin to see why a lot of people have problems with this.
Some of the issues you will run into include coil spring vs leaf spring suspension changes, the engine cross members being entirely different and interfering with the 4x4 front axle, steering systems are completely different and transfer case mounting issues. None of these swaps are bolt-on and all will require extensive fabrication.
will there be weakness in the d44
Yes there is weakness, a Dana 44 is like...16 less than a Dana 60. But seriously, there is a reason why 1 ton trucks came with Dana 60s. A 44 has a weight rating of up to something like 3,500 lbs while a 60 is rated up to 6,500 lbs. It may be OK if you go easy on it, but yes, there is a weakness.
Old Jul 17, 2014 | 01:31 AM
slowrollerzcustoms's Avatar
slowrollerzcustoms
chop cut rebuild lol looks like my frame is going to get my 78 front half
Brown Falcon
Jul 21, 2009 03:13 PM
Livewire88
Offroad & 4x4
Jul 18, 2006 01:34 PM
1977FordF-150
Jul 6, 2003 04:15 PM
Mud Man
1983 - 2012 Ranger & B-Series
Jan 21, 2002 10:36 PM
