so i found a 77 1 ton dually frame but its not 4 wheel drive i have a 1978 front leaf spring dana 44 setup i am wanting to convert my 44 to 8 lug dually front setup. Need help guys i still have the front half of the frame too so i could transfer parts
You could have just clarified .. You could be talking about the spacer needed to convert an F250 8 lug leaf spring front axle to a dually set up .. A leaf spring 5 lug front 4wd axle is a rare bird ..
But at the end of the day I really don't have time for your shxt .. Key word shxt
Here is my rare bird but really need to know if i can convert it to 8lug it needs rebuilt anyways so is it possible to do and put under the 1 ton frame
im building off a 2wd frame but have my 4wd frame to fabricate the 2wd into a 4wd im trying to figure out if my front suspension currently on my 78 will bolt up to the 77 and can i convert it from 5 lug to 8 lug time is not of the essence so if it takes time i dont mind the cab is being sent to my body guy for a house of kolors paint job
The 5 lug leaf spring axles are on 1/2 ton supercabs.
Your best bet is to sell the axle to a jeep guy and buy a 3/4 ton axle. Jeep guys love them because it's an upgrade for them, spring mounts are correct and they can still use whatever wheels they already have because the pattern is the same on each.
