Modular V10 (6.8l)
Fuel Pump Relay
Old Jul 15, 2014 | 12:44 PM
brunomisty's Avatar
brunomisty
Fuel Pump Relay
Does anyone know where the fuel pump relay IS ON A 2002 F-250 V-10 2 wheel drive truck ??? The fuse panel is on the drive side under the steering wheel but I can not find the pump relay
Thanks
Wayne
Old Jul 15, 2014 | 01:16 PM
projectSHO89's Avatar
projectSHO89
Ford Truck Enthusiasts Forums - Search Results
Old Jul 15, 2014 | 06:52 PM
kc day's Avatar
kc day
Just found out today that somehow the "bad" fuel pump burned out the relay in the fuse box. I was told that it's a sealed non-serviceable unit and the whole fuse box (2c7z14a068aa, ford #) needs to be replaced.
Old Jul 16, 2014 | 06:18 AM
projectSHO89
Depends on what your truck is, we don't know since you didn't identify what it is.
Old Jul 16, 2014 | 07:38 AM
kc day's Avatar
kc day
It's a 2002 f250 cc v10.
Old Jul 16, 2014 | 07:42 AM
kc day's Avatar
kc day
From what I understand, the relay is in the central junction box or what looks to me like the fuse block.
Old Jul 16, 2014 | 12:37 PM
Hank85713's Avatar
Hank85713
Kinda hard to figure what you are referring to as a sealed unit? The relay is replaceable, not repairable. You might have to pull the fuse box to get at the wires under it to redo any that were burned if any. Do you have an owners manual? If not go to ford.com and download one for your vehicle. Get a haynes or chilton manual, they usually have a wire diagram in them or you can go to autozone.com and get a copy from their library.
Bottom line I dont know who told you that a fuse panel is sealed, just doesn't make sense.
Old Jul 16, 2014 | 06:02 PM
kc day's Avatar
kc day
It wasn't that the fuse panel is "sealed". It's that the fuel pump relay is somehow sealed in that fuse block and not serviceable, at least that's what I was told. I was told that the fuel pump somehow burned out the fuel pump relay that is located in the central junction box (2c7z14a068aa) and that the only fix is to replace that box. Please, If you have any suggestions on how to replace just the relay or any info on a more inexpensive fix I would appreciate the info, thanks
Old Jul 16, 2014 | 06:21 PM
projectSHO89
On the '02 gasser, the FPR is soldered onto the board in the CJB and is not separately serviceable.
With suitable motivation and patience, it should be possible to graft na eternal relay onto the circuit.
Old Jul 16, 2014 | 06:31 PM
kc day's Avatar
kc day
Thanks for the info. I just don't know why Ford would not make just that relay replaceable.
Old Jul 16, 2014 | 06:33 PM
Hank85713's Avatar
Hank85713
If that is all it is, soldered, a good tech can remove or s suggested a replacement soldered in its place. You will need to pull the fuse panel to see where the traces are and ID the ones for the FP. Then clean all protective stuff off the traces involved and mount a wire block for a relay with the corresponding leads going to the new relay. Would guess its a standard 4 plug. Relays are cheap and a good one can be had for less than $10.
Old Jul 16, 2014 | 09:37 PM
Hank85713's Avatar
Hank85713
Try to find a replacement in a junk yard and then modify either it or the original. The junk yard find may be serviceable and then you can fix the old for a spare! Check see if the blades penetrate thru the board on the original, if so you can solder to them and not the traces. A lot easier. I have a yamaha mc and it has all kinds of solder issues in a component. I got some small gauge aircraft wire and just soldered the wires to the points on the board, no issues since.
rickcaspari
Aug 2, 2024 08:24 PM
landscaper62
Aug 2, 2024 08:21 PM
javila88
Oct 8, 2018 08:19 AM
99f250craig
Aug 21, 2013 03:23 PM
docergo
Jul 17, 2009 08:59 PM
