Sponsored by: Real Truck
Fuel Pump Relay
Old Jul 17, 2009 | 04:29 PM
docergo's Avatar
docergo
Fuel Pump Relay
Where the heck is the fule pump relay on a 2002 f250 gasoline extended cab 4x4?
Old Jul 17, 2009 | 08:24 PM
F350-6's Avatar
F350-6
Welcome to FTE. Are you referring to the little square relay that plugs in to the fuse box? You should be able to find the correct location in your owners manual. If you don't have one, you can download one here https://www.fleet.ford.com/maintenan...ls/default.asp
Old Jul 17, 2009 | 08:59 PM
docergo's Avatar
docergo
f250 fule pump relay
I found the fuse for the fuel pump, that was easy. I did some asking around and found out they use the accessory relay or the relay for Diesel only. I'll try that. I'm still waiting on my Ford Repair/Service manuals and wiring diagrams.
