Clutch Interlock
Old Jul 10, 2003 | 11:13 AM
bennie's Avatar
bennie
Clutch Interlock
1992 F150 5 Speed
To start my truck, it’s like I have to push the clutch peddle thru the firewall to be able to get the starter to turn over. Any thoughts on what the problem may be and how to correct?
Thanks
Old Jul 11, 2003 | 01:45 AM
macguyver's Avatar
macguyver
Clutch Interlock
Check for a switch on the clutch pedal (or is actuated by the clutch pedal) that looks like a brake light switch. It should be adjustable by pushing it in or out.
Old Jul 11, 2003 | 10:16 AM
steve83's Avatar
steve83
Clutch Interlock
It's probably the tubular style that wraps around the clutch master cylinder pushrod above the gas pedal. The Haynes manual shows how to adjust it.
Old Jul 11, 2003 | 12:42 PM
bennie's Avatar
bennie
Clutch Interlock
Yes it is the tubular style that wraps around the pushrod. I'll see if I can find a Haynes manual to look this up.
Old Jul 14, 2003 | 11:15 AM
bennie's Avatar
bennie
Clutch Interlock
Could not find a Haynes manual but I did look at the Ford manual I have on CD and it does not have any adjustment procedures. I also took the pushrod off so I could get a better look at the switch and the set up and did not see anything that would allow for adjustments. Any help would be greatly appreciated.
Old Jul 14, 2003 | 07:44 PM
steve83's Avatar
steve83
Clutch Interlock
The Haynes says it should work properly if installed properly - no adjustment. I'm surprised you can't find it on the CD, but I haven't looked.
Eallend7
Feb 5, 2013 06:31 PM
Welk49
Feb 16, 2009 08:55 AM
geotracker91
Apr 26, 2008 04:35 PM
f100guy
Feb 18, 2008 07:44 PM
Kurt Frome
17
Mar 11, 2004 07:02 PM
