Intermittent Power problem - codes 172,181,565
Old Jul 14, 2014 | 07:26 PM
bkbkbkbk's Avatar
bkbkbkbk
short version : truck misfires and stumbles terribly when warm after it sits for a minute. gets a little better when moving.
longer version
95 300ci 4x4 5sp
Having a difficult to diagnose problem here guys.
If I start the truck up from cold, and run for a good while, say 100 miles on the interstate, it will drive fine until I stop for a couple minutes and restart. It will then drive terribly and misfire so bad I can barely get it going. Once I get going it will drive a lot better but not 100%. Appears to be something affected by the heat while it sets (sensor?). While I am driving now it will throw a code, usually when I go up a hill, but also sometimes downhill or flat. Code has been 181 or 172 (lean or rich from the 02 sensor)
Also has thrown code 565 for a while, even before this problem. That code is Canister Purge Solenoid Circuit Malfunction. Could that have anything to do with this? I do not understand the function of this canister or its purge solenoid. I have pulled that code a couple times in the past, it is just stored and does not turn the check engine light on so I never thought too much of it.
One last 'issue', is the motor will vibrate a bit at 1500 rpm in 4th gear at 45MPH only, feels like a tire out of balance but is obviously the motor, thought it could be a vacuum issue but never could find it and smoke test showed nothing. Could this also be related?
Truck has about 100k miles, well maintained, no vacuum leaks that I could find (smoke tested), replaced distributor, ICM, plugs, wires.
Help?
Old Jul 16, 2014 | 04:34 AM
bkbkbkbk's Avatar
bkbkbkbk
bump. anyone?
Old Jul 18, 2014 | 11:01 AM
bkbkbkbk's Avatar
bkbkbkbk
No one???????
Old Jul 18, 2014 | 12:01 PM
1986F150six's Avatar
1986F150six
I wish I could help you, bkbkbkbk, but mine is carbureted. Sorry.
Old Jul 20, 2014 | 03:59 PM
bkbkbkbk's Avatar
bkbkbkbk
Thanks 1986..
I wont be offended if people just start taking a rough stab at it...
Old Aug 4, 2014 | 05:21 PM
bkbkbkbk's Avatar
bkbkbkbk
bump... some one has to have a guess. EGR related? If it is throwing lean it may be getting way too much air after heat soak?
Old Aug 4, 2014 | 07:41 PM
Harte3's Avatar
Harte3
Do a Google search on the codes like this: ford codes 172
Do that for each of the codes and see what comes up.
Old Aug 5, 2014 | 06:04 PM
bkbkbkbk's Avatar
bkbkbkbk
Spent plenty of time doing that with no significant luck.
Old Aug 5, 2014 | 06:51 PM
bkbkbkbk's Avatar
bkbkbkbk
Dirty MAF sensor? truck does not have one
Could the EGR be sticking open? Wouldn't the EGR position sensor send a code because of this?
Old Aug 11, 2014 | 10:07 AM
bkbkbkbk's Avatar
bkbkbkbk
BUMP
Throttle position sensor??
Old Aug 13, 2014 | 08:07 PM
Drk2's Avatar
Drk2
I never post anything much. I count on the search function to answer my questions. I am having the exact same problem that you are experiencing with the same code 565. My truck is a 95-300-I6 with a 5 speed. My gas mileage is off 3-4 miles per gallon. The power loss is very noticeable and it is sometimes hard to re-fire after running any period of time. I would love for some of the guru to help us figure out this problem.
Old Aug 13, 2014 | 08:22 PM
Drk2's Avatar
Drk2
I have a donor truck that I have swapped out all the different sensors and even the egr. The only thing I haven't changed is the air pump. I have correct vacuum on all components with no vacuum leaks. I am really stumped. I haven't any of the coolant sensors yet. I feel the it is exhaust related somehow. I have read about a possible intake/exhaust leak. I am about to do an engine swap with a replacement 6 cylinder but need to solved this problem first because I don't feel changing the engine will make this go away. Any suggestions would be greatly appreciated.
Old Aug 16, 2014 | 07:44 PM
bkbkbkbk's Avatar
bkbkbkbk
this thread is a dud
bob57434
Modular V8 (4.6L, 5.4L)
Feb 25, 2018 01:48 PM
trdsmn
Dec 10, 2013 08:19 PM
farmer4
Oct 23, 2012 07:22 PM
eclancy
Apr 3, 2012 08:18 AM
BigDa
1997 - 2003 F150
Jan 18, 2010 08:44 PM
