85 ford 6.9
Old Jul 10, 2003 | 09:08 AM
bob ny's Avatar
bob ny
85 ford 6.9
i was wondering about cutting the soupbowl out of the aircleaner. Would it effect the air temp in the winter and how about getting rid of the back pressure in the exhaust. I would like to get some more power out of the truck but still want it run in the winter. thanks
Old Jul 10, 2003 | 12:09 PM
Jens's Avatar
Jens
85 ford 6.9
Hi,
thats a good question. I have both, with and without soupbowl in the aircleaner and I also wondering what the bowl is used for....
Jens
Old Jul 11, 2003 | 09:20 AM
bob ny's Avatar
bob ny
85 ford 6.9
i was thinking the bowl might restrict the air enough in the winter to warm the air. and some back pressure in the exhast could be used to heat things up .. either that or maybe im thinking to much . i thought i might get some more opinions before i change things.
Old Jul 11, 2003 | 09:35 PM
Lobstah's Avatar
Lobstah
85 ford 6.9
I cut mine out last night with a pair of tin snips. First mod I've made. If I have time, I'll try and do the R12-R134a conversion this weekend.
Lobstah
Old Jul 13, 2003 | 09:16 AM
jim_truck12's Avatar
jim_truck12
85 ford 6.9
wow sounds like a cool truck anyone got any suggestions to where i can get some pictures of the truck
Old Jul 13, 2003 | 08:11 PM
argve's Avatar
argve
85 ford 6.9
I removed my soup bowl before I went with the turbo.
Made a slight increase in power (very slight)
Made checking the air filter much easier, you can actually remove the lid without removing the entire assembly.
It was installed to quite the under hood noises. I did notice a slight increase in the noise but not much.
Fuel mileage increase - I don't know, if it did increase the fuel numbers it was not by much. Because I don't remember it.
BTW the colder the air, the more dense it becomes so it contains more O2, which means more power because you get a more complete burn of the fuel your already dumping in the engine. The reason most folks see a power decrease or fuel mileage decrease in the winter is because the fuel is blended to keep it from gelling up in the cold temps. So to offset this run some Stanadyne Performance Formula in the winter, and Stanadyne Lubricty Fromula in the summer. The reason for the Stanadyne is two fold - one it helps lube the pump, and increases the burn factor.
the Forum rules don't allow me to link to where you can purchase the stuff on line, so find your local injection shop they should have it.
Old Jul 14, 2003 | 07:18 AM
Lobstah's Avatar
Lobstah
85 ford 6.9
I've had trouble finding the Stanadyne products locally...so I'm getting ready to order them online. I'm surprised that none of the shops, including truck stops, seem to carry it.
Lobstah
Old Jul 14, 2003 | 07:51 AM
bob ny's Avatar
bob ny
85 ford 6.9
i changed the exhast from a stock muffler and a 2 1/4 tailpipe to a cherry bomb and 3" pipe and tail and im totaly impressed with the diffrence. gained alot more power and sounds alot deaper at mid to high speed. its a whole new truck im impressed.
Old Jul 14, 2003 | 07:52 AM
Lobstah's Avatar
Lobstah
85 ford 6.9
Mine has dual stacks coming up through the bed behind the crewcab, and from the sounds of it, it's pretty much wide open now.
Lobstah
Raleigh1
35
Jan 10, 2013 03:46 PM
MNDiesel2
6.7L Power Stroke Diesel
Nov 9, 2011 07:45 AM
fixdent
Mar 27, 2011 10:51 AM
SteveBricks
S. California Chapter
32
Sep 16, 2008 11:17 AM
74baja
Jul 22, 2008 09:17 PM
