Distributor question
Old Jul 15, 2014 | 03:48 PM
FordFETruck's Avatar
FordFETruck
I don't have any pinging problem with a 925D spring and the factory medium spring, even running the hills with 1000 pounds of weight in the back, with 87 octane. I run NGK UR5 sparkplugs, which are the factory equivalent to an Autolite 24 or Motorcraft ASF-32C
Old Jul 16, 2014 | 03:36 AM
Ken Blythen's Avatar
Ken Blythen
OK, thanks.
I recently found my distributor has been set up with the 10L arm, which explains why it seemed to need so much initial advance to produce good power (also, the vacuum advance had been removed by the PO)........I'm going to change this, but I might look into the springs too.
Old Jul 16, 2014 | 03:41 AM
FordFETruck
Originally Posted by Ken Blythen
OK, thanks.
I recently found my distributor has been set up with the 10L arm, which explains why it seemed to need so much initial advance to produce good power........I'm going to change this, but I might look into the springs too.
Mine is setup with the 13L slot. Works perfectly!
Old Jul 16, 2014 | 04:13 AM
Ken Blythen
Thanks Matthew..........the other arm in mine is a 15L so I'll use that, install a new vac advance, & limit the total.
OrangeJuice
Aug 31, 2010 06:48 AM
jeff8362000
17
Nov 16, 2009 09:43 PM
comochja
Aug 4, 2009 03:56 PM
68 ranger
Sep 21, 2008 08:40 PM
chilly460
May 5, 2000 05:06 PM
