dually 4x4 conversion
Old Jul 13, 2014 | 01:21 PM
afiggis's Avatar
afiggis
I have a 2wd 1988 f350 12' rack dump. I found an 86 dually 4x4 for sale cheap. How difficult is it to swap the front axle and transfer to make it 4x4? I have a ttb front now. Haven't seen other truck yet so I can't comment on it. But as a concept is it doable?
Old Jul 13, 2014 | 03:04 PM
Diesel_Brad's Avatar
Diesel_Brad
By 86 4wd dually, you mean cab-n-chassis correct?
You are going to have to make sort sort of front leaf spring hanger behind the bumper.
You will have to transfer the front spring hangers from by the front mount to your truck.
You will also need a 4wd transmission(is your truck and donor truck the same engine? They NEED to be)
Are the gear ratios the same between the 2 trucks? if not you will have to swap the rear axle too
Old Jul 13, 2014 | 06:36 PM
afiggis's Avatar
afiggis
Tranny is the first problem. The 86 is a 6.9 diesel. my 88 is a modded 351. I know nothing about the 6.9. I thought the diesels had a different c6 than the small blocks. I thought the frames were the same between 2wd and 4wd. Could be wrong. I didn't know if you could swap front end components easily or not.
Old Jul 13, 2014 | 06:48 PM
Diesel_Brad
Trannys are different
86 has a 4 speed (T-19)
88 has C6
You would need small block bell housing to fir the small block. but why not just put a ZF5 in and be down(OD and better fuel milage)
Frames are different because you have coil springs
It depends what you call easy? Do you have torches, welder, drill, grinder, etc? and KNOW how to use them? If so then it is easy. If not, then no. It is not easy
Old Jul 13, 2014 | 08:55 PM
Briansshop's Avatar
Briansshop
That sums it up!
Old Jul 14, 2014 | 07:00 AM
afiggis's Avatar
afiggis
I admit to knowing nothing about the zf5. Is it like many truck trannys where 1st is super low and 5th is 1:1? Or is overdrive really overdrive?
Old Jul 14, 2014 | 08:50 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It's really overdrive.
Depending on which build, 0.76:1
.77 in diesels, I think.
Finding a Windsor bell 4x4 ZF seems to be the holy grail or something...
Old Jul 14, 2014 | 11:10 AM
afiggis's Avatar
afiggis
ah, So I'm not going to find one eh? So I should either not buy it or just use it as a plow truck until it rusts away.
Old Jul 14, 2014 | 11:43 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I didn't say you would never find one, just that they seem rare because of demand.
Some members here have been looking for good ones for a while.
I think a lot depends on your area.
If people don't find one locally shipping can really hurt.
Midwest trans wants $2360 plus shipping for a 4wd Windsor pattern. ($500 is core)
It IS the late model -s47 variant.
Whether you need the extra 50 ft lbs rating depends on how built your engine is and how hard you beat on it.
Old Jul 14, 2014 | 04:20 PM
afiggis's Avatar
afiggis
I'm in CT myself. EXTREME north end. A buddy of mine is a mechanic. He has some junkyard sources I might be able to use. My engine isn"t built too much. 351 with a stroker kit. built for torque.
Old Jul 14, 2014 | 04:25 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Swing by the CT chapter (and maybe the MA one too) and ask around.
I know CT chapter member Reamer has been looking for a 4x4 Windsor ZF for a while.
Diesel_Brad
1st gear is a 5.72 and 5th is OD
I have 2 small block ZFs. Not that hard to find, just need to know where to look(3/4 and one tons that were stick)
Banjo picker1
13
Feb 26, 2018 10:07 PM
GrislteStick
Jul 20, 2017 11:39 AM
kraazie8
Jan 9, 2008 09:16 AM
CheaperJeeper
84
Mar 28, 2007 08:30 PM
redygo
Feb 18, 2004 02:02 AM
