which timing chain set do I buy ? Integrated or non integrated camshaft sprocket
Old 07-12-2014, 04:12 PM
68shortbedmo's Avatar
68shortbedmo
68shortbedmo is offline
Hello I am changing my Head gaskets on my 03 f 150 5.4 and since I was in there I was going to change my timing chain as well. I seen they have two different kits integrated and non integrated camshaft sprockets. I called ford and mine is a non integrated style. My question is can I get a integrated set since it is cheaper, from the best I can tell the only difference is the non integrated comes with cam sprockets. Is there any difference in any of the other parts? Is there any reason I should consider changing the Cam sprockets?
Thanks
Old 07-15-2014, 08:53 PM
Modularation's Avatar
Modularation
Modularation is offline
Change the cam sprockets as they wear as well as the chain since they contact each other. The Motorcraft parts are best but do not come in a kit. I would use the iron tensioners from an '98 model.
donmi
2004 - 2008 F150
06-18-2018 09:41 PM
monsterbaby
03-26-2006 04:15 PM
ranchero77
02-15-2004 06:25 AM
dbarracuda
12-19-2002 03:54 PM
scott9320
06-11-2002 05:08 PM
Quick Reply: which timing chain set do I buy ? Integrated or non integrated camshaft sprocket
