Sponsored by: Real Truck
Large 5th wheel
Old Jul 13, 2014 | 02:42 PM
phillips91's Avatar
phillips91
Originally Posted by Mud Doc
The 250 is gonna be out of wiggle room--and what about the single rear tires at 3450lbs each--that is only 6900lbs of carrying capacity.
As jdadamsjr said--350 minimum--I say 350 dually--but lots of people do it and get away with it.
Joe
It also depends on the 250 as well. In most cases the 250 will have no wiggle room, but some will have plenty. My 250 diesel had a gvwr of 8,600 lbs and weighed 6,500 lbs, so only 2,100 lbs of payload. My sd gasser has a gvwr of 8,800 lbs and only weighs 5,600 lbs, so 3,200 lbs of payload and plenty of wiggle room. For that year model the 250 was identical to the 350 that had a 9,900 lb gvwr, or 4,300 lbs of payload. I would feel comfortable from a legal or truck capability standpoint with my current 250 but not my last one. Like you and others have said, the actual weight of his truck and his trailer are the only way to figure it out. In this case I would recommend a 350 srw or dually, but think a 450 is overkill.
Old Jul 14, 2014 | 04:12 AM
edwinhhawkins's Avatar
edwinhhawkins
Wieghed the work rig tonight at the company scales, 9752 lbs. Bare *** minimum f350 CC. manual windows AM/FM radio vinyl seats 6.7 engine. It has a large utility shell made out of aluminium and I carry a TON of electronic parts (not heavy) and a good selection of Electric over Hydraulic valves and actuators (VERY heavy) not really important to the thread, but interesting to see what peoples rigs weigh in at.
Old Jul 14, 2014 | 05:39 AM
redford's Avatar
redford
FTE Leadership Emeritus
Here's the 2015 towing guide.
http://www.ford.com/resources/ford/g..._SuperDuty.pdf
Old Jul 14, 2014 | 06:09 AM
jdadamsjr's Avatar
jdadamsjr
edwin !
WOW, whata pig ! you gotta go on a diet
without towing you are scaring the trucks gvwr !!!
Old Jul 14, 2014 | 06:16 AM
edwinhhawkins
Originally Posted by jdadamsjr
edwin !
Oh yeah!! Probably way past time to inventory and see what I really need in this thing!! I do work a LONG way from parts, people, help. Stopping the job is a very expensive thing, so maybe ill just tell them i need more crap on here and beg for a F550
Mtrock
May 11, 2018 10:38 PM
clueless101
Apr 16, 2018 10:07 AM
bowler304
Mar 10, 2016 07:24 AM
Chief-e9
All Things Towing
Aug 25, 2011 04:17 PM
grey77
All Things Towing
Aug 1, 2004 11:57 PM
