Front coil springs
Old Jul 11, 2014 | 10:57 PM
Boba Fett's Avatar
Boba Fett
Front coil springs
I need a new pair of front coil springs to replace two cracked units that I found when I went to replace shocks.
I went to Advance to see what is available and found I can get either variable rate coils or constant rate coils. I am pretty sure the springs that came off the truck were constant rate coils. What would you guys recommend for a 79 that runs without a sway bar?
Old Jul 11, 2014 | 11:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Personally I like the variable rate. The rate increases as the spring is compressed. Constant rate springs have the same rate regardless of how much they are compressed.
The variable rate springs give a better ride when the road is relatively smooth or only slightly bumpy.
nikmish
Ford Truck Parts for Sale
Jul 11, 2014 11:24 AM
Xclimation
16
Oct 22, 2012 10:58 PM
wfordpower
Jan 29, 2006 10:33 PM
purevilife
Jun 14, 2005 01:25 AM
SuperHighOutput
Dec 31, 2004 11:41 AM
