biggest carb
Old Sep 8, 2004 | 11:47 PM
dmc919's Avatar
dmc919
biggest carb
whats the biggest carb you can put on a stock 302 and what happens if you put on a carb that is really small or way to big?
Old Sep 9, 2004 | 07:37 AM
jwtaylor's Avatar
jwtaylor
You can put any carb on any engine and it will run, however, it may not run so good. Too much cfm, no bottom end, too little no top end..in either case you would hate the engines performance. A 600cfm will work well on a stock engine and still be fine if you modify it some. Later
strokermax
Sep 28, 2014 04:56 PM
triathlonrunner
1997 - 2003 F150
Oct 8, 2009 09:07 PM
orangeconv
Oct 17, 2008 02:41 PM
roadrage19
Jan 4, 2007 07:12 PM
broncopimpservice
Bronco II
Apr 8, 2002 08:08 PM
