Help on C6 Inspection Plate
Old 07-11-2014, 11:01 AM
Oxfordrider's Avatar
Oxfordrider
Oxfordrider is offline
I am looking for a transmission inspection plate for the C6 behind my 351W. The part number I have is C6AP-7986-A. When I research this all I can find is that the part number works with a big block. It appears to be the correct shape. Can someone confirm that it is the correct part for small block. I am also looking to purchase one. Thanks for the help.
Old 07-11-2014, 11:30 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,479 Likes on 1,416 Posts
There are literally dozens of shapes and sizes of block plates and matching inspection covers for every engine and trans combo, and for different years, too. Frankly, it's a simple enough piece you could probably make one with a piece of sheet metal and a pair of tin snips if you can't find the exact part you need.
http://www.google.com/search?hl=en&s....33.12.0.21.21
The following users liked this post:
Old 07-11-2014, 08:30 PM
ranger pat's Avatar
ranger pat
ranger pat is offline
I looked at the plate on my 351W/C6 and it is a "service" part number. D10Z-7986-A
Call your local FORD dealer part department to see if they have one and they can tell you what the application is used for.
Old 07-12-2014, 04:33 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Oxfordrider
I am looking for a transmission inspection cover for the C6 behind my 351W. The ID engineering number I have is C6AP-7986-A
C6AZ-7986-A .. C6 Inspection Cover - Marked with ID number: C6AP-7986-A / Obsolete
1966/70 Galaxie/LTD/Thunderbird/Fairlane/Torino/Comet/Montego 390/428 / 1967/70 Mustang/Cougar 390/428 / 1968/76 F100/350 360/390.
D1OZ-7986-A .. C6 Inspection Cover / Obsolete
1971/73 Fairlane/Torino/Montego/Mustang/Cougar 351C/W / 1974 Torino/Montego/Cougar 351C/W
1978/79 F100/150 300/302 & F250/350 300 / 1978/93 Econoline 300/302/351W // 1980/93 F100/350 & Bronco 300/302/351W
MUSTANG'S ETC in Van Nuys CA has 1 = 818-787-7634.
PEROGIE ENTERPRISES in Highstown NJ has 1 = 609-448-5593.
TISON MOTOR CO. in Estill SC has 2 = 803-625-2551 (note: listed as D10Z).
Old 07-12-2014, 05:01 PM
Oxfordrider
Thanks for the input. I knew someone would come through with the answer.
AVM123
03-23-2024 07:35 PM
pat420swed
24
08-03-2023 10:13 PM
circlecityrabbit
02-09-2017 08:47 PM
lightning60
WTB - Parts & other
01-27-2010 09:21 PM
JefflovesF250s
11-30-2009 10:40 AM
Quick Reply: Help on C6 Inspection Plate
