Sponsored by: Real Truck
Ford Question
Old Jul 10, 2014 | 10:50 PM
PointerRanch's Avatar
PointerRanch
Ford Question
Okay I have one that I am stumped over. I have a 1999 Ford F350 with a 7.3 turbo. It has been stalling on me from time to time while driving. The only way I get it to start up again is to add oil to it. Then it starts right away. It does not look like the oil is low but I still add one quart and it goes again. Why is this?
Old Jul 10, 2014 | 11:32 PM
JSchuricht's Avatar
JSchuricht
The 7.3 uses high pressure oil to fire it's injectors. If you oil level is too low the injectors won't fire and the truck won't run. Your oil is going somewhere, just a guess but check your fuel filter for signs of oil then replace the injector orings if you find any.
Old Jul 11, 2014 | 04:54 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If the stalling is indeed from low oil you are WAY low. Its not impossible. Heck it's not even uncommon. It's happened to me even. Sounds like that could be the problem.
He is right, the engine creates high pressure oil to fire the injectors. If that flow stops, so do the injectors. However this can be for several reasons, including a weak pump, or bad valve.
If you're wanting to diagnose it, get a high end scan tool, or an android or iOS device and hook up the appropriate OBDII adapter. Check ICP, IPR, etc.
Old Jul 11, 2014 | 01:26 PM
PointerRanch
Thanks for the info. I think my issue is directly related to oil pressure and the injector system. I have been doing some research and what you say is spot on with what I read so thanks a bunch.
Syncrowave
Apr 17, 2016 06:14 AM
philwaters
Apr 4, 2010 08:26 PM
MONAVIERONJON
Feb 18, 2010 11:08 PM
snakyjake
22
Oct 15, 2008 10:53 AM
jasefm
23
Oct 11, 2007 08:28 AM
