Injectors fried?
Old Oct 5, 2007 | 02:55 PM
jasefm's Avatar
jasefm
Injectors fried?
My truck took 35 seconds to start, It would turn slow and make low rpm knocks with no smoke or anything like it was starving for fuel. Then it ran like a champ. The shop says it was four liters low on oil and all the injectors are fried to the tune of $2000.
I checked the oil before it went in and is was 1/4 between the low and marks.
If it is the injectors how difficult is it for me to replace them?
Any other suggestions.
1999 F-350 7.3 PS 4x4 dually quad cab
Old Oct 5, 2007 | 03:03 PM
MR5x5's Avatar
MR5x5
Low RPMs while cranking? Check batteries/connections. Need RPMs to fire. 4 liters low on a 16 liter system... things could be worse.
Old Oct 5, 2007 | 03:05 PM
Green_Dually's Avatar
Green_Dually
I have a hard time beleaving that your injectors are bad,maybe one or two,but not all.And it didn't fry the injectors from no oil,as the 7.3 wont run with no oil.
If im wrong someone will correct me,but from what i have learned,they wont run with no oil.
Old Oct 5, 2007 | 03:37 PM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
It is true. When the 7.3 oil level drops to a certain point it will kill the engine and you cannot restart until the oil level is back up where it belongs. It happened to my wife. I checked the oil. It was not registering on the stick. I added a several quarts and the engine started and ran fine.
Old Oct 5, 2007 | 04:46 PM
jasefm's Avatar
jasefm
Well, now they say the injecters are clogged with sludge and need to be replaced. Oil was changed 4000 miles ago.
Ideas?
Old Oct 5, 2007 | 04:50 PM
WonderDonkey's Avatar
WonderDonkey
Run diesel kleen
Old Oct 5, 2007 | 05:03 PM
Green_Dually
Read this thread,it might be your problem !!
https://www.ford-trucks.com/forums/6...knowledge.html
You might want to check what the 1st poster said in that thread.
Old Oct 5, 2007 | 05:18 PM
jetdoc's Avatar
jetdoc
Ideas?
I would get a second opinion....Before I spent another dime.
Old Oct 5, 2007 | 05:21 PM
jetdoc's Avatar
jetdoc
If it was injectors it wouldn't get better......
Get the codes read. Check the batteries. How old are they? CPS?
Old Oct 5, 2007 | 06:02 PM
Action4478's Avatar
Action4478
Get Your Truck Away From Them......
Old Oct 5, 2007 | 10:43 PM
bdrummonds's Avatar
bdrummonds
grab a bottle of HOT SHOTS SECRET from these folks http://campaigns.ford-trucks.net/cam...s&bannerid=427It goes in the oil and cleans out the oil passages in the injectors. the Diesel Kleen cleans out the fuel passages.
they are a FTE sponsor so you can buy with confidence.
Old Oct 6, 2007 | 04:11 AM
jasefm's Avatar
jasefm
Sounds good
Originally Posted by bdrummonds
grab a bottle of HOT SHOTS SECRET from these folks http://campaigns.ford-trucks.net/campaigns/direct.php?log=yes&bannerid=427It goes in the oil and cleans out the oil passages in the injectors. the Diesel Kleen cleans out the fuel passages.
I will take your advice. Thank you all so much for all all the great advice. I will certainly let everyone know of the out come.
Old Oct 6, 2007 | 05:09 AM
dcara's Avatar
dcara
" grab a bottle of HOT SHOTS SECRET from these folks http://campaigns.ford-trucks.net/ca...es&bannerid=427 It goes in the oil and cleans out the oil passages in the injectors. the Diesel Kleen cleans out the fuel passages. "
How long before an oil change should this be done in order to get all the stuff out that has been freed? How often do you use it?
Old Oct 6, 2007 | 05:42 AM
Kwikkordead's Avatar
Kwikkordead
I agree with everyone else here - your injectors are the last thing to suspect in this.
How much fuel is in your tank at the time that it was giving you trouble? The fuel pickups in these truck have a terrible design that will introduce too much air to the fuel if the tank is allowed to run low.
Old Oct 6, 2007 | 09:14 AM
bdrummonds's Avatar
bdrummonds
You'll have to check the directions, but IIRC it was for 3000 miles(minimum) and was safe to use for a full OCI.
there was a thread back in the spring that the sponsor posted in and gave all the details. I think his name is Chris Gabe, his user name on here is Lubrication Specialties, if you want to send him an email.
