Sponsored by: Real Truck
Removed cat.
Old Jul 10, 2014 | 09:17 PM
shotgun64's Avatar
shotgun64
Removed cat.
Here in pa the f250 super duty pickups are exempt from emissions because of weight. I removed my cat and got more top end but I can more torque. I replaced my coil packs last year. Any help?
Old Jul 11, 2014 | 04:57 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Other than "any help?" I don't see a question in there.
Cash you clarify?
Old Jul 11, 2014 | 05:38 AM
Modularation's Avatar
Modularation
You are still under federal emission rules so be careful what you post.
Old Jul 11, 2014 | 05:54 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I'm not aware of federal emissions rules. Only state. Not that I've looked into it.
But there are a lot of trucks running around without cats, DPFs and EGRs.
I'd also be surprised if the feds use forums to find smog dodgers
Old Jul 11, 2014 | 09:02 AM
Modularation
$10K fine to shop removing them.
Big Brother is...
Old Jul 11, 2014 | 09:05 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
For a shop.... That's different. I have a sawzall
Old Jul 11, 2014 | 11:06 AM
dkf's Avatar
dkf
Doesn't matter, it is still illegal under federal law for anyone.(on road use)
I am in PA also with an F-250 too and there is an emissions inspection. I am only exempt from emissions inspection if I drive less than 5,000 miles a year. I still need to pass an OBD scan, gas cap test and visual anti tampering to pass emissions. No "sniffer" test. PA is broken up into regions and things vary slightly depending on region.
The OP changed the velocity of his exhaust by ditching the cat and loss of low end is the result. You can try a set of long tube headers like the Thorleys to maybe pick up some low end. But I think you will end up living with your decision or putting a cat back on.
Old Jul 11, 2014 | 07:16 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I know. I'm just saying I don't know what the law is that makes it illegal for us at the federal level. I thought it was at the state level, and if your state doesn't require you to do emissions then so be it.
If anyone can cite it... Much appreciated.
Old Jul 11, 2014 | 09:01 PM
EXv10's Avatar
EXv10
what is your address?
Old Jul 11, 2014 | 09:07 PM
mecdac's Avatar
mecdac
Old Jul 11, 2014 | 09:17 PM
dkf's Avatar
dkf
Pot is illegal on the federal level but not on the state level in Cali.("medical") The feds just aren't going to make a fuss over the small amount of pot "moonbeam" whom got a medical card due to his hangnail has in his pocket.
In PA things are broken up into regions (several counties to a region) however federal law is still valid. Welcome to the wonderful world of government where confused is right where they want you to be.
If you want to remove a cat IMO your best bet is to pull it, gut it and put a pipe through the inside. Then reinstall it making it look as untampered with as possible. Something that should not be illegal IMO, just don't go attracting extra attention to yourself. The oe cats can develop a rattle either internal or heat shields a good excuse to replace it for a better flowing aftermarket cat.
Last paragraph page 7. Notice it covers "individual" not just businesses.
http://www.epa.gov/otaq/cert/factshts/catcvrts.pdf
Old Jul 12, 2014 | 06:22 AM
Number21's Avatar
Number21
Yep, watch out! They will record your IP address, look you up, and do a sting outside your house. Next time you go to the store for a quart of milk, watch out for the swat team!
In the real world, if you are not subject to an emissions inspection, then you can do what you want. Nobody will ever check, and in fact, nobody has the authority to check. They can't just pull you over and check for a cat, that isn't legal.
Even if you were subject to an inspection, the worst that will ever happen is that you will fail and your vehicle will not be registered. They will tell you to go put the cat back on. It is NOT illegal to remove the cat on an unlicensed vehicle. Many shops will do it legally for "offroad use only". You will not be fined. Yes, cats are part of the federal emissions regulations, but, there is no federal emissions inspections, inspectors, or testing! I would also bet that only applies to federally maintained roads.
It's funny, I actually spent about 10 minutes talking to the local cops about the straight pipe on my 6.0. Technically it might be "illegal", but they loved the sound and we talked about his Cummins with a similar exhaust.
CoastieMK
Apr 21, 2009 05:52 PM
mememe
Jun 13, 2008 12:17 AM
Scott97F150
Exhaust Systems
Oct 2, 2007 08:28 AM
Bowcop
Oct 11, 2003 03:15 PM
Knobby4604X4
Exhaust Systems
Sep 14, 2003 10:36 PM
