1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
hidden ball hitch
Old 07-10-2014, 12:06 PM
JesseFixesCATs's Avatar
JesseFixesCATs
JesseFixesCATs is offline
hidden ball hitch
Anybody know of a good company to get a hidden ball hitch for gooseneck trailers for a 2012 f250 diesel fx4 short bed. Im needing the whole mounting kit. Ive already looked under the truck and its got a hole in the middle of the bed for it under the bed liner.
Thanks.
Old 07-10-2014, 01:28 PM
phillips91's Avatar
phillips91
phillips91 is offline
B&w, Reese, drawtite, hidden hitch or turnover ball would have what you are looking for.
Old 07-10-2014, 01:41 PM
Desert Don's Avatar
Desert Don
Desert Don is online now
Received 4,735 Likes on 1,678 Posts
All of the above are reputable companies.
I am personally using the B&W turnover ball with their 5th wheel companion hitch.
Old 07-10-2014, 02:33 PM
JesseFixesCATs
Thanks guys ill look in to those
Old 07-10-2014, 04:27 PM
1120MS's Avatar
1120MS
1120MS is offline
Thanks for this info ... this is in my list of to do's for my F350 and this post saves me time in researching.
Old 07-10-2014, 06:39 PM
iamrfixit's Avatar
iamrfixit
iamrfixit is offline
B&W turnover ball, look no further.
Been using this hitch for 10 or 12 years, it's pulled some huge loads and continues to do so. I have zero complaints, my best friend liked it so much he has had one in all 6 of his trucks and uses them commercially running far more miles with a trailer than he does without. This hitch has almost become the standard that the others get judged by.
Old 07-11-2014, 11:04 PM
1120MS's Avatar
1120MS
1120MS is offline
What model#'s are you using for the B&W turnover ball and 5th wheel companion? Thanks ...
Old 07-26-2014, 12:07 PM
FERdter's Avatar
FERdter
FERdter is offline
B&W Turnover Ball Issue
On my 2007 F350 Diesel the B&W was there when I purchased the truck.
It has the F X 4 off road package and had standard shocks & 3" lift.
I switched to Rancho 9000 and with about a 1500 Lb load the B&W hitch mount dented the staggered shock on the passengers side. Luckily it didn't puncture the shock but there is a pretty good dent just below where the tube tapers out from the piston shaft.
My fix was to use a 3" cut off wheel on a die grinder and remove about 1/4" of the sharp corner on the frame mount of the B&W bracket.
I don't use the Flip ball hitch so I'm not worried about any minor loss in the mounting strength.
Just for your info.
Richard
rbrockman
Fifth Wheel & Gooseneck RV Towing
05-06-2017 03:42 PM
WilliesSD250
Alaska Chapter
07-23-2009 10:44 AM
Stewart_H
11-18-2008 02:51 AM
97 HD
09-03-2007 08:53 PM
HOGman1024
05-21-2006 11:54 PM
Quick Reply: hidden ball hitch
