My wife's 99-expy-xlt-5.4L has some play in the steering.
The steering wheel can be turned about 2" from 12 o'clock either way before I feel any resistance.
Could the tie-rods be shot? I am experiencing wear on the outside of the front tires, especially one side.
Is there a test for tie-rods on Fords? My BMW is simple, you jack it up and hold the wheel at 3 and 9 o'clock and look for play....however, the Ford is huge and I'm not sure how much play i should feel.
Check for play between the steering wheel shaft and the input shaft of the steering box. Known '97 plus problem with bolt locking the shaft to the box installed incorrectly OR in backwards.
