Good deal?
Old Jul 10, 2014 | 12:46 AM
crewcab96's Avatar
crewcab96
Good deal?
An old friend of mine has a 79 F150 short box with a healthy 400 (flat top pistons, cam, intake, 750 double pumper, etc) and a 6" lift on 40" ground hawgs. Interior is pretty good. Body is straight, no rust. Needs paint and eventually new tires. He cant register it in California due to smog and I live in Nevada in a part where smog isn't required. He told me he would let me have it for $1000. Does that sound like a pretty good deal?
Old Jul 10, 2014 | 02:22 AM
AK FORD GUY's Avatar
AK FORD GUY
If it runs and drives, no rust and the only real need is tires... $1000 is not bad at all.
But, if it's a $1000 project truck that is going to swallow up a bunch of your cash... Take a second look and make sure it's in your budget.
Old Jul 10, 2014 | 07:48 AM
redroad's Avatar
redroad
If the short wheel base body and frame are in restorable condition then it is a decent deal but the 40" tires on that front axle if it's original is a big mistake .. If the tires were run long on it the whole front axle will need to be rebuilt along with the rest of the drive train .. Check the frame over real well for bends or breaks because this setup (40" tires) is way under engineered for this frame and drive train ..
Old Jul 10, 2014 | 10:03 AM
bassdude's Avatar
bassdude
It's a horrible deal, don't do it. as a matter of fact just go ahead give me his number so I can give him a call and tell him that.
Seriously? if I had a chance at a good short bed with little rust and a good motor and interior for a grand it would already be sitting in my driveway.
Old Jul 10, 2014 | 10:09 AM
landers0440's Avatar
landers0440
I second this. If you don't take it I sure as hell will. Around my parts you can't find anything like this that has very little rust on these old trucks.
Old Jul 10, 2014 | 10:54 AM
61steven's Avatar
61steven
As others have said, take a good look over. If the frame is not bent and the axles are not yet trashed, it could be a steal. If the truck was not used as a woods or desert toy for very long the axles can hold up. However, they are a ticking time bomb.
Around here 1,000 will buy you a truck with more rust than metal. No interior and tires from the 80's.
Old Jul 10, 2014 | 11:23 AM
fordcrzymike's Avatar
fordcrzymike
If the truck is how you describe it to be, then 1,000 is a hell of a deal. Look it over, make sure it's not a total money pit, but for 1,000 it's not too much of a risk. Even if a lot of the truck is trash, you could part it out and get your money back.
Old Jul 10, 2014 | 12:05 PM
crewcab96's Avatar
crewcab96
I helped him put a new trans and rear end in it a few years ago. No rust. No frame damage. It had 33's on it most of its life then he put the 40's on about a year ago and just used it around the ranch during the winter since then. I know its always been a reliable truck for him for the 10 years he's had it. I just wasn't sure what they're worth.
Old Jul 10, 2014 | 04:03 PM
fordcrzymike
Usually more than 1,000 if it's not a POS
jake wells
Feb 24, 2011 10:01 AM
OvalHunterNY
Nov 11, 2009 07:25 PM
Nightrain
16
Dec 10, 2006 02:19 AM
JBradley500
Jul 10, 2006 02:14 PM
SEAN74F100
Jul 14, 2003 06:30 PM
