Dual Modular Valve
Old Jul 9, 2014 | 07:58 PM
garry11268's Avatar
garry11268
Dual Modular Valve
Wondering what's the purpose of dual vacuum port modular valve on my 1973 f-100 C6 transmission? Needs to be replaced. Could I change it to a single port vacuum modular valve ?
Old Jul 9, 2014 | 08:31 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That had to do with emissions, I forget the exact reasoning behind it though. That's the pink stripe modulator.
Yes, you can go with the single line modulator. Get the black stripe (or green stripe) and delete the vacuum line that goes in the side of the modulator.
Old Jul 10, 2014 | 09:27 AM
fmc400's Avatar
fmc400
MSEE
I'm told that the dual-port valve was used on some EGR setups. There was a concern that the signal strength to the valve would be lowered when the EGR valve was open; so the same signal that goes to the EGR valve was ran to the secondary port of the dual-port valve to give a little extra pull. I'm also told that it's not really necessary, so there's no problem capping off the secondary port or switching to a single-port valve as Mike describes. I did the former on my Galaxie and had no problems.
Old Jul 10, 2014 | 04:38 PM
garry11268's Avatar
garry11268
Thank both of you very you very much..... Very informative.
Claudia Tull
Dec 15, 2016 06:37 AM
ApocalypseBob
Aug 11, 2015 09:13 PM
jonmark1985
Jun 25, 2013 05:53 PM
rdweathers
Jul 13, 2010 05:07 AM
sandrat
Feb 26, 2003 03:43 PM
