I have a 6.9 idi and I've been wanting to turbo it. I came across a turbo and I bought it real cheap. I was wondering where I could order the up pipes, y collector, oil lines, ect.. thanks.
What exactly are you wanting to do? No one makes replacement parts, and finding pieces used is nearly impossible. If you want to build from scratch i suggest a muffler shop. If you want to build it yourself buy the pipe and bends... oil lines at a hydraulic shop.
What kind of turbo? I'm assuming you have a truck and a truck turbo kit?
I'm more worried about getting the up pipes and the y. I could make them but I'd rather just buy them. The turbo I got was made by mack. It's pretty small.
Any model numbers? Post some pics. Also, put some info about your truck or van.
My truck is a 85 f250 regular cab long box. 6.9 idi c6 tranny 4x4. I have a small mack turbo to put on and need the up pipes from the manifolds for the turbo to go on.
Your either going to have to build your own up pipes and Y pipe and make it all go together, or find a used ats or banks kit to the get pieces your looking for.
You can't buy just those pieces brand new
Banks still sells replacement parts for their sidewinder kit. They should still have the cross over pipes and up pipe casting. The up pipe isn't cheap though, I think I remember reading $400-ish for that piece alone. By the time you bought the coss over pipes, down pipe and brackets you might as well find some used kit that has it all.
