Radiator/Cooling Help!!
Old Jul 19, 2014 | 05:55 PM
  #46
Memphis_Sean's Avatar
Memphis_Sean
YOU NEED THAT SPRING IN THE LOWER RADIATOR HOSE!. Some new hoses don't come with them, so you have to pull the old one out of the old hose and stick it in the new hose. If you get a overheating problem going down the highway, it's because you didn't put the spring in the lower hose. At high rpms and temps, the hose gets very flexible and will suck shut and restrict waterflow.
I'm not overly worried. No spring to re-use. Where can I buy a spring? I'll check out the yard if I have to/when I have time.
Old Jul 21, 2014 | 06:35 PM
  #47
Memphis_Sean
Anyone know where I can buy just the spring for the radiator hose??
Old Jul 21, 2014 | 06:52 PM
  #48
FordFETruck's Avatar
FordFETruck
Don't know about where you can get one. But my V8 doesn't have one in either hose and never has had a cooling problem while in my possession.
Old Jul 21, 2014 | 10:35 PM
  #49
Memphis_Sean
Thanks for the reply. Yeah, I look at it more like insurance then an absolute necessity. I contacted Dayco, the manufacture of my rad hoses and they said the spring isn't "required" in their design. So, insurance.
Old Jul 21, 2014 | 10:48 PM
  #50
FordFETruck
My bottom hose is a Gates, top is a Motorcraft.
Old Jul 22, 2014 | 12:29 AM
  #51
Memphis_Sean
I got mine at Auto Zone. I just replaced them along w/ my water pump and tstat.
Old Jul 22, 2014 | 01:30 AM
  #52
FordFETruck
I have no idea how old mine are, probably when one of the PO's replaced the radiator. But the hoses are in very good shape and aren't very old.
Old Jul 22, 2014 | 08:47 AM
  #53
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Never have I had worse problems than a convoluted lower Dayco hose for my 460.
I cut that thing off and threw it away as soon as I could order in a Gates replacement.
Never again.
Old Jul 23, 2014 | 05:53 PM
  #54
Memphis_Sean
No problems what so ever w/the Dayco Hoses I have on my 4.9. Also, here is what the Dayco Tech, told me about using a hose spring.
No you do not need a spring. We removed the springs in 2000 because if there was blockage in the system, they could possibly suck into the impellers of the Water Pump. If the Coolant system is working properly, the hoses will not collapse.
We no longer offer springs, and do not sell them in our line. I don’t believe anyone is selling them now in Aftermarket hoses. You should be OK with 71038 and 71281 as they are.
Thanks for contacting Dayco,
Roger Richardson
Roger Richardson
Product Application Technician | DAYCO Products, LLC
Old Jul 23, 2014 | 06:43 PM
  #55
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Well good for them.
I don't see how the spring could get sucked into the water pump given how it has to be wound up just to get it into the hose.
Yes, it will never be an issue if the radiator is not clogged and there is pressure in the system.
That said, their lower rad hose for a 460 is the flimsiest and most poorly fitting POS I have ever bought.
"Never again"
Old Jul 23, 2014 | 07:28 PM
  #56
Memphis_Sean
Originally Posted by ArdWrknTrk
Well good for them.
"Never again"
To each his own. However, the hoses I bought were good quality and fit like they should. None of the hoses I could find/buy new, had a spring in them. Gates, Goodyear, NAPA, etc.
Old Jul 23, 2014 | 07:43 PM
  #57
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm in agreement with you.
If it fits and works, that's great!
I don't see the lack of a spring to be a big issue if you take care of your cooling system.
In fact I'm sad that my personal experience was not as good as yours.
Old Jul 23, 2014 | 07:55 PM
  #58
Memphis_Sean
I use to run a spring in my Mustang Track Car (I think I bought it at Summit Racing). But w/the response from the tech and the fact no one uses them in new hoses (at least for my application), I'll find other stuff to do/talk about LOL
SgtOtaku
May 9, 2017 10:21 PM
triumph1200
1947 and Older Ford Trucks
Mar 8, 2017 08:47 PM
Raleigh234
Nov 17, 2015 05:54 PM
wosborn
Jan 22, 2002 08:18 AM
