Radiator/Cooling Help!!
Old Jul 13, 2014 | 01:22 AM
  #31
Memphis_Sean's Avatar
Memphis_Sean
I'm usually one for research as well, but its sad one has to do endless research and track down good parts :/
  #32
Memphis_Sean
Originally Posted by FordFETruck
Yes it is, sadly. I did some good research for a good thermostat and the Motorcraft RT1139 is the best one I could find. Cost me $13 though but it's a USA part and works perfectly.
Where did you get it at?
Old Jul 13, 2014 | 01:26 AM
  #33
FordFETruck's Avatar
FordFETruck
I bought mine on eBay. Cheapest place I could find it. It came from a Ford dealer in Illinois I believe. I noticed the body is quite a bit thicker over the parts store thermostat I had.
Old Jul 13, 2014 | 01:30 AM
  #34
Memphis_Sean
Yeah, I was just on ebay. It says its not for an 85'. I'll have to confirm. I believe you can special order Motorcraft Thermostats from Oreilly's too.
Old Jul 13, 2014 | 01:33 AM
  #35
FordFETruck
What engine do you have? the body is the typical Ford/GM/Chrysler thermostat body.
Old Jul 13, 2014 | 01:40 AM
  #36
Memphis_Sean
I have the 4.9L/300.
Old Jul 13, 2014 | 01:44 AM
  #37
FordFETruck
Should fit just fine. This is actually the seller I bought mine from.
http://www.ebay.com/itm/MOTORCRAFT-RT1139-190f-88c-Thermostat-/220814932940?pt=Motors_Car_Truck_Parts_Accessories&hash=item3369987bcc&vxp=mtr
Says it fits 1983 300 Six trucks, no reason why it shouldn't fit an 85. They all use the same thermostat to my knowledge.
Old Jul 13, 2014 | 01:48 AM
  #38
Memphis_Sean
Yeah, thats the one I saw. I guess I'll just run the 160 until I can get one or just go get a regular one. Well, gotta get up early before the sun hits (110 tomorrow) to replace the jacked-up water pump I was sold.
Old Jul 13, 2014 | 01:56 AM
  #39
FordFETruck
I thought 90 was bad here...
Old Jul 19, 2014 | 03:53 PM
  #40
Memphis_Sean
*UPDATE* WP replaced...went more or less smoothly. Radiator hose spring....who's using one/who isn't?
Old Jul 19, 2014 | 04:01 PM
  #41
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I use one.
Comes with the Gates ECR hose for my 460.
Old Jul 19, 2014 | 05:05 PM
  #42
Memphis_Sean
Originally Posted by ArdWrknTrk
I use one.
The 4.9 hoses didnt come with one (Oreilly or AZ). The NAPA ones on there, didn't have them either and were pretty worn. I went w/the better priced AZ ones.
Old Jul 19, 2014 | 05:13 PM
  #43
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A new hose is always good!
Old Jul 19, 2014 | 05:18 PM
  #44
Memphis_Sean
LOL...yep (seeing as I was doing the WP, tstat and belts too)
Old Jul 19, 2014 | 05:47 PM
  #45
Franklin2's Avatar
Franklin2
YOU NEED THAT SPRING IN THE LOWER RADIATOR HOSE!. Some new hoses don't come with them, so you have to pull the old one out of the old hose and stick it in the new hose. If you get a overheating problem going down the highway, it's because you didn't put the spring in the lower hose. At high rpms and temps, the hose gets very flexible and will suck shut and restrict waterflow.
