Try Your Hand at Diagnosing This Problem
Old Jul 7, 2014 | 10:11 AM
shortwide's Avatar
shortwide
I recently solved a problem with my 66 and since I like diagnosing and fixing various issues on my old cars, I figured I'd make it into a "challenge" of sorts...for the entertainment of you fine folks here at the FTE.
I'll post the symptoms here and then the solution later today. (the single solution to both problems was simple and cheap)
Here are the symptoms:
(First a description of the truck ---> 1966 F100 240 3 speed, absolutely bone stock, 65K original miles)
- After running the truck and shutting it off, fuel drips from the linkage at the base of the carb, on to the intake manifold
- Autolite 1100 recently, carefully rebuilt.
- Truck extremely hard to start when cold
- Once fired up however, it runs perfectly, idles perfectly, and if turned off and turned right back on, it starts instantly.
- If allowed to sit more than a few minutes after running, it is extremely hard to start.
Like I said, one thing was causing all of the above.
Good luck. I'm proud to announce that the winner gets.....well nothing. Nothing at all. But I get a kick out of solving minor issues on this old iron and I figured some of y'all might too.
Last edited by shortwide; Jul 7, 2014 at 10:14 AM. Reason: fixing my grammar....sometimes I wonder what the hell my 8th grade English teacher was doing.
Old Jul 7, 2014 | 10:26 AM
svolpone's Avatar
svolpone
Float level too low?
Old Jul 7, 2014 | 11:03 AM
crazed87bronco's Avatar
crazed87bronco
Gas boiling out the carb heat soaking?
Old Jul 7, 2014 | 11:18 AM
daveengelson's Avatar
daveengelson
My guess is power valve; either the power valve, gasket or warped housing. If leak is coming from between lower and upper housing then one or the other is warped or gasket needs to be replaced??
Old Jul 7, 2014 | 11:53 AM
kjvforme's Avatar
kjvforme
Bad seat on the float seat causing flooding of the carb and to rich of a condition at start? Throttle shaft bushings worn, causing low pressure area to change location with in the carb.
Old Jul 7, 2014 | 04:42 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Carb needed spacer plate C5AZ-9A589-A or equivalent?
Old Jul 7, 2014 | 07:16 PM
nineteensixt5f100's Avatar
nineteensixt5f100
loose bolt at the carb base???
Old Jul 7, 2014 | 07:23 PM
rusbukt's Avatar
rusbukt
Stuck shut heat riser valve.
Old Jul 7, 2014 | 10:12 PM
shortwide's Avatar
shortwide
Lot's of great potential solutions offered up....more than one of which could've caused the issues.
My particular, easily solved, problem was nailed by TA455HO and indirectly nailed by Crazed87Bronco.
The spacer plate was missing between the carb and intake manifold, causing the fuel to boil in the float bowl, which caused the dripping gas and engine flooding, but only when the engine was brought up to full operating temp.
Installed spacer, problems went away.
Thanks for playing!
Old Jul 7, 2014 | 11:02 PM
nineteensixt5f100
so if the winner gets nothing, then the runners up get???? well I guess a learning lesson
Joshua1960
22
Feb 1, 2023 05:50 PM
dziwei
52
Nov 22, 2018 05:51 PM
TheKirbyMan
39
Apr 14, 2013 07:00 PM
77f100guy
Dec 14, 2012 12:54 PM
71LTD390
Sep 5, 2004 10:40 AM
