Motorcraft 2150 2bbl won't idle
The week before the switch, I was noticing that I was smelling gas fumes when I'd first start the truck. The exhaust has always smelled pretty rich, but this was more than I was used to. I was smelling raw gas as well as the rich exhaust. Despite this, the truck ran normally and had very good power and throttle response, but horrible mileage.
After taking the Edelbrock back off and putting the 2150 back on, I can get it to start, but it won't stay running unless I'm constantly mashing on the gas. It won't idle at all or hold steady RPM. If I'm not pumping it while it's running it will sputter out and die right away. I even had a flame pop out of the top of the carb as it was sputtering out this afternoon, but I'm thinking that was from me pumping the pedal so much that it had a small backfire and ignited. It went out on its own, fortunately.
I replaced the power valve with a brand new one from NAPA; there was fuel all over the old one as well as in the little cap piece that screws down over the PV. With the new power valve I did notice the exhaust tone sounded a little different than before, though performance didn't change any. This could be from my having reset the idle mixture screws to the baseline 1.5 turns out, though
So far I have done the following:
- Set idle mixture screws to 1.5 turns out from bottomed-out (not too far off from where it was originally)
- Checked carb gaskets (I did have to reuse one for the spacer but I bolted everything down tight, and it wasn't damaged)
- Checked for loose vac lines, found a cracked cap, replaced it
- Made sure vac advance was hooked to ported vacuum
- Checked for fuel spray upon throttle application (accelerator pump is OK)
- Replaced power valve (old one was shot and covered in fuel) and installed new gaskets for PV and its cover
- Checked fuel output from fuel pump, pump is OK
- Checked for fuel-fouled plugs (pulled three random ones, one was a bit dark but dry, I cleaned it)
- Spark is OK
- Plugs are about two years old but in good condition
- Wires are new
- Cap and rotor are in good condition
- Timing has not been changed from where it was before the swap
- There is fuel in the tank (I overlooked this once...lol)
At this point I don't know of any other things I can replace without having to disassemble the carb, and I don't think I have the gaskets handy for it anymore. I do plan to replace the carb as soon as I get my rebuild kit for the Edelbrock installed, but if possible I'd like to see if I can get the truck running so I can have a vehicle of my own to drive so I don't have to use my mom's Cherokee so much.
Thanks in advance.
You are checking the right things, but it sounds like you have a big vacuum leak somewhere. The only other thing I can think of is your old carb had some sediment in the bottom of the bowl, and when you took it off it got sloshed around and stirred some of this dirt up and now it's clogging things up.
I agree with Dave that it sounds like you have a large vacuum leak. Pumping it squirts raw fuel into the mix and helps to cover up the lean problem. While I kinda doubt that it would be enough to do that, it is very possible to have a hole in the vacuum advance diaphragm. But, you said that you have it hooked to ported vacuum, so it shouldn't cause much, if any, problem at idle.
Do you have EGR? If the valve is stuck open you will have a lot of problems at low RPM.
Also, I called my uncle today and told him what's happening, and he said that it sounds to him like the timing chain might have either jumped a tooth or just be stretched out. What's ya'll's thoughts on that?
But, when it is stretched and you have poor running with jerking, backfiring, etc the chain can jump and come down in another spot on the sprocket. Then it won't run well at all. However, if you put the E'brock back on and it runs sorta ok then it isn't the timing chain but carburetion. Or, fuel induction might be more correct as it might not be the carb but the manifold and/or gaskets.
Have you tried going to the E'brock again? If it runs the same as the 2150 then we'll know it isn't the carb, although it still might be the intake. And, it could be the timing chain. If it runs ok then it isn't the timing chain and isn't the intake - gotta be the carb.
Sort of.
It sounds like it's firing on every other cylinder, yet it runs pretty smoothly with no backfiring whatsoever. If I ease into the throttle and get the RPM up, it will actually hold the RPM and then it roars to life and sounds like it's supposed to, I'm thinking from the secondaries kicking open.
I'm pretty sure once I rebuild it, it should idle right and run properly. If not then we know I need a proper 4bbl intake, though I do hope the adapter works good enough to do me til I get some money for an intake.
Makes me wonder what made the 2105 go nuts. A friend said it sounds like the floats got stuck, but once I get the Ebrock installed and running I'll tear that 2105 apart and figure out what's up with it.
I can't wait to see what my gas mileage is with the E'brock though. Hopefully it'll be better than what I was getting.
Don't get side tracked. It would be a very rare occurrence for another problem to crop up while you are messing with something else. There is a 99% chance that the problem is caused the carb swapping, I would keep concentrating on that area.
If I absolute have to get an intake I can, but if possible I'd like to make this work til I have a little more money.
