I'm interested also, one day if I ever stray from stock. Problems I see are that a full window may not roll down as the door hinges are bolted on under the wing window, will electric window kits still work, and if I have no air conditioning then no way.
I'll probably just get the kit to re rubber the wing for now and save all that for much later.
Anyone delete their vent windows and install a single piece of glass? Id like to try this, think it would look trick.
Adding it to the to do or try list. Just wanting any insight if its been done.
This has been discussed here before but I couldn't find the thread. Perhaps another search.....anyway, Bobs F100 or somebody used to sell a kit that required a lot of modification of the inner hinge area. Some guys thought it really weakened the doors. Don't know if they still sell it. I found another thread where astronaut made his own kit. It might give you some ideas....https://www.ford-trucks.com/forums/1...nt-delete.html
So far everything I am thinking about is just that "my planning". I had seen that 64 through google search and like it quite a bit. I really like the gas fill option as well, but Im a stepside guy so Im going to have to go a differnt route.
Im certain I can do it, just curious if anyone else had done it and had any pre cut and weld tips
Lambo is a bit over the top for my taste, but I honestly have been thinking about suicide doors. Will also solve my problem (or create a whole new set of them............
