Headlight Problem
Old Jul 6, 2014 | 10:39 AM
thinker77's Avatar
thinker77
Headlight Problem
I am not sure if this has been covered or not. I have a 2003 Ford Excursion Eddie Bauer 6.0L that I bought and noticed the headlights are not working.
The brights come on when I pull back on the signal lever. However when I push the lever forward the headlights do not stay on. In order to get home last night I wedged a dime in the lever space to keep the brights on so I had light while driving.
Brights work with lever pulled back.
Headlamps do not work on auto, or manually turning on. FOG lights do work correctly.
Reverse, Turn signals, Hazards, Break lights, and amber front signals all work as they should. The low beams do not work at all.
Any ideas? thanks guys you usually save my a$$ when i can't figure something out
Thanks so much and happy 4th
Marc
Old Jul 6, 2014 | 08:02 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
check your fuses first, then wiggle your relays, not sure if they are in the fusebox under the steering wheel or under the hood on the drivers side.
Old Jul 13, 2014 | 11:55 PM
superdave02f552's Avatar
superdave02f552
I'm thinking multifunction switch
Chance12
General Automotive Discussion
Jul 16, 2013 08:21 AM
jjdoyle
Jan 3, 2011 08:38 AM
huskermark764
1997 - 2003 F150
Dec 6, 2008 12:18 PM
John Thomas II
Oct 18, 2004 07:22 PM
