trying to figure it out
Old Jul 2, 2014 | 08:59 PM
getchasome1991's Avatar
getchasome1991
I have a 95 f-150 flare side. I have a small block 302 in it. My dad races swamp bugges and had a built 460 with about 900hp. He built a 383 so he sold me the 460 i want to put it in my truck. But it has a carburetor on it and mine is fuel injection. Do i have to switch the intakes or is there something i can do to leave it with the carburator? And i already have a built c6 trannsmission and stock heads with a little work to them and a diffrent crank. So i can run pump gas. What do i have to do.
Old Jul 2, 2014 | 11:41 PM
85e150's Avatar
85e150
Welcome to FTE.
This 460--it had 900 horse, but you are talking about detuning it with stock heads, different crank (?) and wanting to run pump gas?
Why switch it out then?
Sorry, but the questions you are asking indicate you need assistance beyond internet suggestions. You should leave your running, driving 302 in place.
JMO, ymmv.
Old Jul 3, 2014 | 12:57 PM
Conanski's Avatar
Conanski
The 302 and 460 share absolutely nothing in common so you are looking at a complete powertrain swap here.. engine, transmission, driveshaft and rear axle, because that big block would shred the stock F150 parts if you could bolt it up... which you can't. There are no parts on the 302 that will work on the 460 so it would seem like you are using a carb on it.. hopefully you don't have emissions tests to pass because it wouldn't even come close.
69 lil' Red Shane
Aug 15, 2012 03:12 PM
Rick L
23
Jul 12, 2010 10:49 AM
marcsmithracing
Engine Swaps
May 23, 2009 07:45 PM
Dunkindonuts97
Ford vs The Competition
60
Oct 6, 2005 06:30 AM
