Silicone sealant
Old Jul 2, 2014 | 08:19 PM
tbax46's Avatar
tbax46
Silicone sealant
I am confused. I just had to replace a HPOP that was under a year old. The tech said it failed because silicone was used as a sealant. Supposedly it caused the seals an rings to pull apart. Now I see where Ford has a silicone sealant. Some here please explain all this.
Old Jul 2, 2014 | 11:11 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
There are several areas on the 6.0 silicone is used... one being the HPOP cover where the block mates with the rear cover.
Josh
Old Jul 3, 2014 | 06:22 AM
cheezit's Avatar
cheezit
Silicone is used at the T joints only on the pump cover, ta29 or ta 31 ( same stuff different tubes) silicone only. Grey silicone is formulated so it does not react to oil or cause unwanted oil foaming
Old Jul 3, 2014 | 10:34 PM
tbax46's Avatar
tbax46
Seems when installing my previous HPOP the tech used silicone on the o ring and the whole went down the tubes. They did honor the warranty on the pump. Of course I got stuck with the labor. Now I've got a new HPOP, ICP sensor, standpipes, dummy plugs, o rings and IPR.
basstardo
Apr 25, 2017 09:18 AM
ROBBINthaHOOD
Nov 19, 2011 09:07 AM
lads_john
Oct 17, 2011 06:35 PM
fordbronco1966
Nov 24, 2010 09:33 PM
strato1
Jul 18, 2008 08:21 AM
